Old 02-12-2019, 07:34 AM   #1
1977 Argosy 20
Olive Branch , Mississippi
Electric jack blows fuse every time.
I have a 1977 Argosy 6.0 Minuet. Every time the electric jack is maxed out it blows the fuse. So far it has only done this while in the up position.
Detailed explanation:
While trying to relocate the trailer from the driveway to the backyard we tried to use a 2016 Dodge Ram. The ball was too high for the tongue and the jack maxed out. Upon trying to lower the jack again for a shorter ball on a smaller pickup (2012 Toyota Tacoma) the jack wouldn’t budge. We located the fuse box and determined it had blown a fuse(first fuse blown). We replaced the fuse and tried again.
As soon as I touched the switch it wired up and stopped(second fuse blown). It was then that we figured out it would blow a fuse each time it maxed out in the up position.
Having not been familiar with the trailer since we JUST GOT IT, we didn’t know which direction to flip the switch to go down so it was a 50/50 chance we were gonna blow that fuse too. Well, I flipped it the wrong direction and it blew(third fuse blown). That was our last fuse. We replaced the fuse wrapped in aluminum foil and now that I know I had to flip the switch to the passenger side of the trailer to let it down we could do so.
Twist: when we relocated the trailer from my grandparents house to mine the jack worked fine. It never blew a fuse but we also aren’t sure that we had to max out the jack at all. So this is either a new problem for the trailer or we unknowingly haven’t encountered this problem yet. However, the fuses we had on hand were the exact fuses needed to replace the blown fuse for the jack. They just happened to be stashed in the cabinet. Could this have been a pre-existing problem my grandfather dealt with and he knew to keep the fuses on hand? He’s been in heaven for two summers now so I can’t ask him and my grandmother doesn’t know.
Any advice, experiences or comments are greatly appreciated. TIA
Argo20 is offline   Reply With Quote
Old 02-12-2019, 09:26 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
My 04 did the same thing, only if I fully retracted it not extended. When at the factory I put it on the warranty claim list and turns out the power jack when fully retracted would come in contact with the supply wire, short it and blow the in-line fuse.
They said they fixed it, but it never really worked as advertised. I just make sure not to fully retract it and when it dies, will replace with a unit that is better than the OEM that was installed.
Given the age of your unit (assuming the jack is also fairly old), high power draws from it sticking or not functioning as it did when new could also blow a fuse in an overload situation. Jacks are sort of like disposable razors, unless it's obvious and an easy fix, more times than not, just less of a hassle to replace IMHO.
Old 02-13-2019, 08:31 AM   #3
richw46's Avatar
Lexington , Kentucky
On my AS, when the jack maxes out it hits a limit switch and cuts off the power. Perhaps your jack doesn't have the switch or a previous owner has removed it/wired around it.
You can use a Sharpie to put a small arrow for UP on one side of the switch to let you know which way to press it so you don't blow fuses.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 02-13-2019, 10:44 AM   #4
2018 25' Flying Cloud
Portland , Oregon
My brand new 2018 did the same thing. The dealer had to replace the jack. I eventually replaced the jack with a Husky anyway which is a far better, quieter, jack. I wouldn’t mess around with it.
daleyocum is offline   Reply With Quote
Old 02-13-2019, 12:54 PM   #5
Not a new member
2006 22' Safari
1989 29' Excella
2003 25' Safari
Warren , Oregon
Airstream A-frame jack fuses
Jacks are notorious for blowing fuses. Change the fuse out to an automatic resetting fuse of the same value (30A probably). Get the auto reset fuse at Napa. It has a bigger case so hope it will fit where you need to put it. Mine is in the line to the jack and there is no room problem. Sometimes, to get a better connection, you have to trim the edge of the fuse socket (outside, in-line fuse). I always protect the connection with a couple of wraps of electrical tape.
reputnam503 is offline   Reply With Quote
Old 02-13-2019, 12:56 PM   #6
Aluminut
2004 25' Safari
. , Illinois
+1 for the Husky, on my list when mine finally dies.
Old 02-13-2019, 02:14 PM   #7
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Or do it on your terms, not a malfunctioning unit in the rain on a holiday at a full camp!
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Jack fuse blows when changing direction pcskier Jacks, Stabilizers, Lifting and Leveling 28 06-17-2018 02:18 PM
Barker High-Power Jack Blows Fuse While Driving Woodguyco Jacks, Stabilizers, Lifting and Leveling 23 09-19-2015 09:15 PM
Dometic RM2501 constantly runs the igniter? blows fuse... WineStream Refrigerators 19 08-30-2009 07:09 PM
Turning on TV lights blows fuse when trailer connected shinybean Lights - Interior & Exterior 4 08-16-2009 09:48 PM
28' CCD: Right turn signal blows fuse michaero 2002 - 2005 International 4 11-30-2004 09:09 AM
