Old 10-15-2012, 10:01 AM   #15
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Early '70s Argosy Parts
Greetings GLovedahl!
Originally Posted by GLovedahl View Post
Does anyone know where to find a fuse block for a 1978 Argosy Minuet?
You have several options when approaching the 12-volt fuse panel. There are a few modern power converters that have built-in fuse panels similar to the original Univolt, but there isn't a large selection of potential models with this feature. Most automotive parts stores as well as automotive stereo stores often sell 12-volt fuse panels that can be adapted for service in an RV with minimal changes. It is also possible to purchase an electric service panel that combines 120-Volt AC breakers on one portion with 12-volt fuses or breakers on the other portion.
When my Minuet needed a new power converter to replace its original Univolt, I purchased a new Magnatek converter that was then being used in new Airstreams. This converter had a built-in fuse block with modern automotive "blade-type" fuses. The only thing that I don't like about this particular converter is that it has a tendency to boil the electrolyte if left plugged-in while the coach is idle . . . . it is better than the original Univolt, but still not ideal in terms of battery life.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 10-15-2012, 10:02 AM   #16
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The general recommendation is to use a modern fuse block that uses the blade-type automotive fuses. This one made by Progressive Dynamics is what the PO installed in my '75 Argosy, and it works well. There may be other sources for it, that's just the first one I came across with a photo and a description.
The advantage of that one or one like it is that the fuse block is "stand alone" and just needs to be mounted somewhere, it includes a cover to protect the fuses and the structure of the fuse block stands it off whatever you're mounting to.
David
Old 05-03-2014, 11:15 AM   #17
1972 Argosy 20
Anchorage , Alaska
Originally Posted by jungleterry View Post
Hello,i just received a whole trailer full of Argosy parts.I only needed a couple to complete my Argosy so there is allot of extra interior parts,cabinets, 2 gouchos,bathroom sink,toilet,shower ,tub curtain (original),kitchen sink,stove,counter top,working refrigerator,cushions,shades,water heater,furnace,faucets,any interior piece is here.Please let me know if you need any items,i can send pictures.Thank you very much.These are to nice to waste.
Take care
Terry and tammy
Hi
I just bought a 1972 20' Argosy. It's real nice all original, even got owners manual.
I need a few parts;
Roof vent cover for plumbing
Shower panel that the hot and cold knobs stick out from.
Is there a front cover available to protect the windows?
Thank you
jcinak is offline   Reply With Quote
Old 05-03-2014, 01:21 PM   #18
DKB_SATX's Avatar
1976 Argosy 28
Originally Posted by jcinak View Post
Hi
I need a few parts;
Thank you
You can use the same front cover that a narrow-body Airstream does if you want a hard cover. Some of us use canvas covers with high-density foam for a bit less protection but easy removal.
The plumbing vent parts are standard-issue Airstream.
The shower panel is the tough one. I don't know of any reproductions that are on the market.
David
Old 05-04-2014, 07:38 AM   #19
Bex
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
Hi
I need a few parts;
Thank you
There are several places in the USA that you can buy the items you need. In addition, use the search function for the rock guards that have been made by many on the forums.
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 05-05-2014, 10:14 AM   #20
1972 Argosy 20
Anchorage , Alaska
Thanks for the help
Hi
I need a few parts;
Thank you
Thanks for the suggestions. I will use your advice and take care of my new baby.
Old 09-11-2016, 08:14 AM   #21
1973 Argosy 26
Walnut , Illinois
Do you have a front door side window for a 1973 argosy. ?
Sturt97 is offline   Reply With Quote
Old 11-06-2018, 02:22 PM   #22
1975 Argosy 24
Las Vegas , Nevada
Parts
Do you still have Argosy parts for sale?
menmoe is offline   Reply With Quote
Old 11-07-2018, 10:17 AM   #23
1978 Argosy 27
1976 Argosy 26
Elk Rapids , Michigan
What are you looking for? I have a bunch of stuff in Fernley, NV and more here in Michigan.
matthewsx is offline   Reply With Quote
Old 11-08-2018, 08:35 AM   #24
1975 Argosy 24
Las Vegas , Nevada
Argosy parts
I am looking for the fiberglass panel that mounts just below the rear window and runs behind the toilet into the shower stall. This panel also has the mount for the shower faucet. The panel also has a pocket shelf that sets just behind the toilet.
Old 11-08-2018, 01:20 PM   #25
1978 Argosy 27
1976 Argosy 26
I pulled one from my '78 this summer. I'll take a look in my storage and see what shape it's in.
JOhn
Old 11-30-2018, 06:36 PM   #26
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
If I can jump in here, I am looking for a couple of the original 15" rims for our 1976 Argosy CB. The rims are six (6) bolt type, seven inch (7"), zero offset.
Anyone?
newsgauger is offline   Reply With Quote
Old 02-28-2019, 10:48 AM   #27
1976 Argosy 28
Terrell , North Carolina
I will have 4 once I order my new rims if you are still looking. It may be a few months before I get a chance to order them though.
-David
dhbinkley is offline   Reply With Quote
Old 02-28-2019, 10:51 AM   #28
1976 Argosy 28
I'm looking for a 18' awning roller tube for a carefree awning....and I have a 17' if anyone is interested.
'75 Argosy for salvage and parts drauchenberg Argosy Motorhomes 9 02-01-2013 10:48 PM
Argosy, Parts, Projects masseyfarm All Argosy Trailers 1 12-11-2011 09:46 AM
Scale plans for early '70s Tradewinds Madmike 1970-79 Tradewind 2 07-30-2011 11:03 AM
