06-06-2014, 03:00 PM
1974 Argosy 22
Hamilton
, Montana
Door lock won't when door closed
LaTortuga's (74 Argosy rear door) door lock will not lock unless it is open. When I shut the door and try to turn the key to lock it, it is stopped as if jammed 3/4 of the way there.
If I open the door, I can turn the key until it locks as it is supposed to, but when it is latched (closed), I cannot get the key to turn all the way.
Short of a new lock set, any advice, this could be a showstopper as far as National Parks...
also, removing the old one looks like a lot of fun..
06-06-2014, 03:04 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
The lock is probably out of alignment with the striker. The door may have sagged or the wind might have caught it one time too many. I'm not familiar with your vintage unit, but there may be adjustments you could make to the lock or the striker plate - or a locksmith could if you're not comfortable doing it.
Hopefully someone with your model might chime in.
Paula
06-06-2014, 03:08 PM
1974 Argosy 22
Hamilton
, Montana
I just replaced the striker plate, but looks fine, as much as I can see in there...
06-06-2014, 03:09 PM
1968 24' Tradewind
Oxford,
, Mississippi
I had issues on my 68 as well. I think Foiled Again is on target and the bolt is not fully extending into the striker plate. If the Alignment is ok you might try what I did. I took my lock apart and cleaned the 40 plus year old grease off the bolt and polished the bolt and also polished the striker plate with Flitz polish on a felt bob with my Dremel tool. After a cleaning and polishing, the door shuts with ease and locks and unlocks with no problems.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
06-06-2014, 03:43 PM
1974 Argosy 22
Hamilton
, Montana
Taking the lock apart, gee that looks like fun. NOT!
Thanks for the advice!
06-06-2014, 03:50 PM
1968 24' Tradewind
Oxford,
, Mississippi
There are just 2 screws that hold it to the door. I didn't take the "guts" apart, just sprayed with brake cleaner to power clean all the gunk and the re-lubed with white lithium grease.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
06-06-2014, 06:58 PM
1972 Argosy 20
Snoqualmie
We had the same issue on our Argosy. I took the whole assembly off, cleaned everything up and re-greased the moving parts. Put it back together and 1/2 hour later all works well. This was an easy project, but a word of caution; if something doesn't move easily don't force it. I recall there are 3 screws holding this on (maybe a different lockset?) one of which is kind of hidden.
06-07-2014, 08:46 AM
1974 Argosy 22
Hamilton
, Montana
Got it out, yuck, 40 year old grease!
I think I see the problem, and yes, it seems the has sagged just enough.
May have to machine the jamb just a bit.
How difficult is it to install a deadbolt on an Argosy?
06-07-2014, 04:17 PM
Virginia Beach
, Virginia
Lipstick Test
Lipstick (an old one that isn't wanted by a female in your family) is a good way to measure stuff for cutting. If you're installing drywall, outline the electrical boxes in lipstick, dry fit the sheet pounding the electrical box against the back of the sheet, then pull the sheet off and cut the boxes PERFECTLY. (The residue can be removed with kleenex.) Same for the strike that is hitting the jamb... just a little lipstick on the end of the lock strike. Turn the key til it hits the jamb. Then a little surgery with a Dremel tool and you're good.
Paula
06-07-2014, 04:35 PM
1974 Argosy 22
Hamilton
, Montana
Many thanx Foiled Again, that is a stellar idea.
06-08-2014, 07:08 PM
1972 Argosy 20
Snoqualmie
Paula
Damn! I've been using a tape measure, testing and retesting before cutting, for years. This is too simple. What a great idea! Thanks for a great tip.
06-09-2014, 04:16 PM
1974 Argosy 22
Hamilton
, Montana
It does now thanks to Foiled Again and Dr.Dremel. We can lock LaTortuga finally!
While removing the gaucho cushions in prep for installing the new water pump-strainer, etc, I noticed the water tank has indeterminate stains, and since we cannot inspect it internally and it isn't kings ransom, we are opting for a new tank.
06-09-2014, 05:40 PM
Corona
Make sure the striker pocket has the brass shim in it and that it's still good.
That shim prevents the striker bolt from wearing, which in turn causes other problems.
06-10-2014, 08:16 AM
1974 Argosy 22
Hamilton
, Montana
Brass shim?
Where exactly and what does it look like?
