Old 03-10-2019, 07:31 PM   #1
1977 Argosy 20
Olive Branch , Mississippi
Door is warped and weather stripping is rotten
I have a 77’ Argosy 20’.
The door is slightly warped and doesn’t seal 100%. Has anyone encountered this problem? How did you fix it? Also, what have you used for weather stripping on your door?
Argo20 is offline   Reply With Quote
Old 03-10-2019, 09:47 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
There are many threads on the subject of re arching the door.
There are You Tube videos as well.
Old 03-11-2019, 05:27 PM   #3
1977 Argosy 20
Thank you
Thnx Twinkie. I’ve searched for these posts and can’t find any. I have used the words “warped, bend, bent, rearching and weather stripping” and can’t find anything on the topic of molding the door back to its original shaped. This is the main entry door btw, I didn’t specify. For those who chime in later
Old 03-11-2019, 08:36 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Just type how to straighten an Airstream door in to Google.
Old 03-11-2019, 09:31 PM   #5
Long Island , New York
If you are on a computer/laptop using the desktop version of this site, the new search function in the blue box above works great. The search function in the AF App apparently does not work as well. You can also use a general Google search and add the search term "site:airforums.com" to the search request.
"straighten door" -- https://www.google.com/search?q=stra...=airforums.com
"bent door" -- https://www.google.com/search?q=bent...=airforums.com
Go to time stamp 7:00 here for the main door:
Good luck,
Peter
Old 03-12-2019, 09:57 AM   #6
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
Here's a link to the gasket for a 77.
https://www.vintagetrailersupply.com...p/vts-1099.htm
Make sure to clean the surface well.
fwjumper is offline   Reply With Quote
Old 03-13-2019, 06:06 AM   #7
1977 Argosy 20
Omg thank you guys!!!! I was seriously getting down about this!
Warped Door? Rivetedude Doors & Locks 8 05-11-2005 03:02 PM
Door-in-Door weather stripping 59er General Interior Topics 3 06-22-2004 08:40 AM
Warped door Baja Bound Doors & Locks 9 08-28-2003 07:42 AM
Two ?'s Furnace and weather stripping escapeez Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-15-2002 06:10 PM
