Old 03-07-2012, 10:01 PM   #1
susans69's Avatar
1976 Argosy 26
Lake Wales , Florida
door handle
Where would I look to purchase a new door handle for my 1976 argosy 26'?
susans69 is offline   Reply With Quote
Old 03-07-2012, 10:16 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
They are very expensive. In the neighborhood of $500.00. There are kits you can buy for less but require some work to install. If I may ask. What is wrong with your existing handle?
Old 03-07-2012, 10:30 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
A photo might be helpful too.
Show us what the problems is.
Vaughan
Old 03-08-2012, 06:36 AM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I bought one form Out-of-Doors Mart when we started the refurb of our '72/ Pricey, yes. Good quality though, and we've had no issues with it for the last 3 years, although she has not been on the road yet.
Check out this thread for an alternative (post 14):
http://www.airforums.com/forums/f206...ock-87671.html
Chris
Old 03-09-2012, 06:12 AM   #6
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
You state door handle. Outside or inside handle? Or do you really need the whole expensive lock mechanism? Inside handles are not too bad: Oasis RV in Tucson or Inland RV would be good to try. Out of Doors mart?
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 03-09-2012, 06:51 AM   #7
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Anything on this page look correct?
VintageCampers.com :: Vintage Campers, Vintage Trailers, Vintage Parts, Vintage Restorations
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 03-10-2012, 11:45 PM   #8
susans69's Avatar
1976 Argosy 26
door handle
the problem seens to be broken pins on the inside
Old 03-11-2012, 08:16 AM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If it is the roll pins. They can be replaced.
There are a couple of reasons these pins break. Pulling the outside handle too far when the door is opened. Slamming the door also contributes.
I have been successful in repairing the assembly on my trailer. If you PM me I can send you photos of what to look for.
Old 03-11-2012, 09:09 AM   #10
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Sounds to me like a KT 200 lock. Ditto on the above parts sources. You used to be able to send your lock to Inland RV and they would repair. The locks are pretty simple to repair if you are half way handy. I have a diagram somewhere I can post or fax if I can find it. Let me know. Maybe someone will beat me to it.
Old 03-14-2012, 01:20 AM   #11
susans69's Avatar
1976 Argosy 26
door handle
Any pictures would be helpful. I believe I have repaired it except I think I am missing the part that locks the door from the inside,
Old 03-14-2012, 02:40 AM   #12
An exploded view of the KT lock can be faxed or e-mailed to you.
If you wished, you can PM that info to us and we will be glad to help you with that drawing.
Old 03-14-2012, 10:11 AM   #13
Lumatic's Avatar
1993 34' Excella
Images: 16
If it is the part I am thinking it is a knurled steel knob that screws into a hole on the inside of the door lock. It is still available, for about $40 the last I heard. but a hardware store machine bolt for about 40 cents will also do the job just fine.
Old 03-18-2012, 12:36 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I used a machine screw and slid a piece of rubber tubing over it. It works great. Cost less than $.50.
Bath door won't stay shut dgmelp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 14 03-09-2012 07:28 AM
Exterior door stop/latch? ehodg66 Doors & Locks 9 03-06-2012 07:11 AM
Dometic model#2600 door seals susans69 Refrigerators 2 03-04-2012 08:24 PM
Door bell repair, where is the fuse? vonprum Classic Motorhomes 7 03-04-2012 02:48 PM
