Old 03-22-2012, 07:58 PM   #15
susans69's Avatar
1976 Argosy 26
Lake Wales , Florida
door handle
What size machine screw did you use? I got all of the other parts i needed. Thank you for all the info!
susans69 is offline   Reply With Quote
Old 03-23-2012, 07:46 AM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I believe it is an 8-32 x 1". I'll check and if it is different, I will let you know.
Old 03-23-2012, 09:15 AM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I just went out and checked. It is 6-32 x 1 1/2". The rubber tube I slid over it is about an inch long. I made the tube from a small piece of vacuum hose. Put the hose over the screw then a small washer, then screwed it into the lock mechanism. Tightened it just enough to prevent the screw from backing out on it's own.
Old 03-23-2012, 10:33 AM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You could also look for an 1 1/2" shoulder bolt with 6-32 threads. It will probably have an Allen head, which would even be better.
Old 05-28-2012, 11:06 AM   #19
darryl97420's Avatar
1974 Argosy 28
Coos Bay , Oregon
I have unbolted the latch from the door because it didn't work. Does anyone have pics of this repair? What pin breaks?
Anyone?
darryl97420 is offline   Reply With Quote
Old 05-28-2012, 11:11 AM   #20
Anyone?
There are more than one part that can fail that would not allow the lock to work properly.
What happens when you try the lock from the outside?
What happens when you try the lock from the inside?
Old 05-28-2012, 12:58 PM   #21
1974 Argosy 28
Coos Bay , Oregon
It worked from the outside but not inside.
Old 05-28-2012, 03:26 PM   #22
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Out of Doors Mart has photo's of the lock assembly on their web site. Exploded views as well.
Did you find a screw for the inside lock?
If you have it out of the door it should be relatively easy to determine what is not working.
Are you saying the door doesn't lock from the inside or the inside door handle doesn't open the door?
Old 05-28-2012, 11:07 PM   #23
1974 Argosy 28
Coos Bay , Oregon
Actually I have never tried the lock itself but the latch works on the outside but not the inside.
Old 05-29-2012, 08:13 AM   #24
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Are you sure the inside handle is not just rotating on the shaft? There is also a roll pin involved with the operation of the inside handle. The inside handle rotates a shaft that has a pawl on the end. The pawl pushes the bolt shaft via the roll pin to retract the bolt.
If you go to the Out of Doors Mart web site and find a photo labeled 3045_5(1). It clearly shows the roll pin and pawl assemble for both the inside and outside handles. The inside handle mechanism is on the left.
Old 05-29-2012, 05:58 PM   #25
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
I picked one up today (machine bolt/screw) and screwed it in as per TGTwinkie, above. I put a little loctite thread seal, so we shall see how secure it ends up being. At least I now have a working lock again.
Thanks for the info.
Bex
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 05-30-2017, 02:29 PM   #26
1976 Argosy 24
South Lake tahoe , California
Anyone here know how to get the lock assembly out of the door? My internal lock pin snapped off and i want to try and remove it but dont think i can without taking it out because the grabit tool yo extract the brokeoff section doesnt reach into the hole where the snapped pin lives.
amilash is offline   Reply With Quote
Old 05-30-2017, 10:23 PM   #27
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
There are 2 screws on the inside of the door and one on the edge of the door near the bolt. You may have to drill the rivets out which hold the seam together at the center of the door in order to remove the lock assembly. Of coarse you will also need to remove the inside handle.
Bath door won't stay shut dgmelp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 14 03-09-2012 07:28 AM
Exterior door stop/latch? ehodg66 Doors & Locks 9 03-06-2012 07:11 AM
Dometic model#2600 door seals susans69 Refrigerators 2 03-04-2012 08:24 PM
Door bell repair, where is the fuse? vonprum Classic Motorhomes 7 03-04-2012 02:48 PM
