Old 08-05-2007, 05:41 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Disconnected Battery while driving
If I disconnect my battery while towing, will all vital driving systems still work...ie turn/brake signals and brakes?
Dan
Dan S is offline   Reply With Quote
Old 08-05-2007, 05:44 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
no your emergency brake will not work on the trailer.
john
you call them ferrets, i call them weasels.
Old 08-05-2007, 05:46 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Yes, all of the lights on the trailer as well as the brakes are powered from the TV. In case of a break away condition the brakes will not work since at that point the power to the brakes would be from the on board battery.
Richard
Old 08-05-2007, 06:11 PM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Another consideration besides the lack of breakaway protection, is that without your trailer batteries connected, your "normal" braking gets its juice from the TV battery and its power wire to the rear bumper which makes more opportunity for voltage drops to the brake magnets.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 08-06-2007, 11:53 AM   #5
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Dan, is there a reason why you need to disconnect the battery? Is this a short trip that you feel is worth the risk involved? Or are you just curious?
I guess I am...
Pat
pmclemore is offline   Reply With Quote
Old 08-06-2007, 12:15 PM   #6
Arlington Hts , Illinois
Images: 8
Last year I needed to tow my 1964 Globetrotter sans battery, because it had tipped and spilled, and I hadn't replaced it yet. I covered the contacts so there was no shorting. The trailer brakes seemed to work OK, but there appeared to be some kind of voltage drop, as the brake lights and turn signals operated dimly at best. The problem dissappeared when a battery was reinstalled. Just FYI.
koltys is offline   Reply With Quote
Old 08-06-2007, 08:41 PM   #7
Dan S's Avatar
1975 Argosy 26
OK, here's the deal
I poped a A/C and alternator fuse in my tow vehicle after towing the trailer for 5 hours. I figure it's related....reason being, whenever I plug in the trailer to the Tundra, the reverse lights come on the truck. It was never an issue and I figured I'd address it later until ths happened.
I found the bad fuse and after replacing it the AC, fan all worked but I decided to unhook the battery for the return trip. With it disconnected, the reverse lights do not come on but everything else seems to work fine.....
Dan
Old 08-06-2007, 09:16 PM   #8
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
you have a wiring ptroblem. I would fix it. You never know when your trailer may disconnect from your TV. in my case the breakaway saved my trailer.
see my website in my signature. under 2006, truck trailer accident.
Michelle TAC MT-0
Sarah, Snowball
Old 08-07-2007, 12:01 PM   #9
Ready-to-Travel
pmclemore's Avatar
I kind of figured that you were asking for a reason. I'm glad you made it home ok. But note Michelle's experience - you never know when something like this might happen.
Pat
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
Battery Level Display uwe Electrical - Systems, Generators, Batteries & Solar 4 07-04-2002 07:31 PM
