Old 12-21-2008, 11:44 AM   #1
buffaloman's Avatar
1978 Argosy 24
1977 Argosy 28
Darrington , Washington
Question Difference of weight between Argosy & Airstream
I was looking at some old sales information about the Argosy 76/77. The 22 models were 34-3700 pounds and the 24' were 3610 pounds total weight. That is about 1,000 pounds lighter than the same airstreams. How did they remove the weight?
buffaloman is offline   Reply With Quote
Old 12-21-2008, 11:46 AM   #2
Ottawa , ON
Took out the excess profits?
(just kidding!)
Old 12-21-2008, 11:58 AM   #3
1972 Travelux Princess 25
Cobourg , Ontario
For a start I believe the Argosy is narrower than the Airstream. Plus they were sold as a lower cost, less lavishly equipped trailer.
If the appointments and accessories were lighter and the body was lighter then the running gear could be lighter too.
The advantages of simplicity and light weight.
What amazes me is how heavy the newer trailers are. But they are wider than the old ones and contain luxuries undreamed of in the 60s. Plus I think the designers assume everyone has a 3 ton 400HP SUV to pull them with so why worry about keeping weight down.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 12-21-2008, 01:03 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The weight is really not that far off. In 76 the Safari 23' was around 3400 and the 25' Trade Wind was around 4200. I am not sure what the listed dry weight was for the Argosy models.
Richard
Old 12-21-2008, 02:13 PM   #5
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
We own a 77 20' Minuet and a 24' rear door. The Argosys were lighter due to the interior cabinetry. The cabinets ware made of aluminum skins not wood or particle board. The frames and shells are the same except for the end caps with are steel.The Minuet is narrower by 6" but the 24' is the same width as the older standard body trailer. I believe the wide body came out in the late 90's.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 12-21-2008, 05:29 PM   #6
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
I also had a '77 Minuet for a short time that had plexiglas windows rather than glass. As Gary said, all of the furniture framing was lightweight aluminum rather than wood, and rather than using plywood or veneer, they used thin aluminum sheeting covered by wood-look contact paper. Some Minuets even had a composite aluminum honeycomb floor.
Argosy was the test bed for ideas before they got used on the silver trailers. That way, Airstream could figure out what worked and what didn't without compromising their flagship product.
Roger
Old 12-21-2008, 06:43 PM   #7
buffaloman's Avatar
1978 Argosy 24
1977 Argosy 28
thanks for the insight. The use of aluminum cabinentry seems to reduce weight but not structural regidity. What do people think of the cabinetry?
Old 12-21-2008, 06:58 PM   #8
1964 26' Overlander
1977 25' Tradewind
To raise a fire storm I like aluminum cabinets much better than particle board cabinets and less than quality all wood cabinets. I have yet to see quality cabinets in any trailer but ones installed by owners.
Peace
Gary
Old 12-21-2008, 07:30 PM   #9
mandolindave's Avatar
Besides aluminum cabinet, and door frames.........
The Argosy panels and surfaces of the dinette , gaucho and walls are made with 1/4 inch ply ( something ) covered in fake ( vinyl? ) wood. I have been replacing mine with real 1/2 inch wood ply where possible. The dinette was especially flimsy.
mandolindave is offline   Reply With Quote
Old 12-21-2008, 07:43 PM   #10
78GussyTX's Avatar
1978 Argosy 30
Alvin , Texas
Images: 8
"Plus I think the designers assume everyone has a 3 ton 400HP SUV to pull them with "
Uh oh mines's only 390
78GussyTX is offline   Reply With Quote
Old 12-21-2008, 09:39 PM   #11
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Images: 90
I think it depends on the model and year. In our minuet there are no wood surfaces. It's all aluminum (some vinyl clad). Heck, even the floor is aluminum.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 12-22-2008, 08:21 AM   #12
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
I like the aluminum cabinetry in the Minuets. My only complaint is that Argosy wasn't always careful about having things at right angles and cut to correct size. Working with the metal is reasonably easy, however, so some of the shortcuts can be redone 'to spec'. I think it would be a good idea for those with aluminum floored Minuets to put in some kind of synthetic wood floor to distribute the load over the floor. Aluminum floors tend to dish over time. They don't spring back as plywood does.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 12-22-2008, 09:41 AM   #13
strmstr69's Avatar
Auburn , Washington
The gospel according to my owner's manual, my '76 26 foot is 3830 bare boned, and 6200 GVWR.
Hope this helps.
strmstr69 is offline   Reply With Quote
Old 01-23-2009, 07:46 PM   #14
buffaloman's Avatar
1978 Argosy 24
1977 Argosy 28
I am looking at a 74 24' model in CA. I'll tell you how it turns out. frankly I am going forward to towing 1,000 pounds less. The particle board in my airstream is so dark. I am getting tired of it.
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Difference between AS and Argosy? mandtclassic Member Introductions 10 04-23-2008 11:58 AM
Reese & Equalizer: Functional difference? Boondocker Hitches, Couplers & Balls 16 07-18-2007 09:33 AM
What is difference between 1 & 2 Battery systems? tvadman1963 Batteries, Univolts, Converters & Inverters 11 01-30-2007 10:36 AM
Difference between Dry Weight and GVWR wacnstac Towing, Tow Vehicles & Hitches 6 04-05-2006 07:29 PM
