Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 04-19-2007, 05:54 PM   #1
gergstuff
Profile:  1978 Argosy Minuet 6.0 Metre
Ferndale , Washington
Dent removal
Hi,
I have a 1978 6 metre Minuet that has some dents in the aluminum panels above the rear bumper. I cannot see any way to access them from behind to try and pound them out without ripping apart the whole back end. Does anyone have any ideas? I would think a traditional slide hammer would wreak havoc on the soft aluminum panels trying to pull the dents from the outside.
I am open to suggestions.
Gergstuff
gergstuff is offline   Reply With Quote
Old 04-19-2007, 07:19 PM   #2
n2916s
Profile:  1986 31' Sovereign
Miami , Florida
You may be able to pull minur dents out with a toilet plunger -- I managed to get one more or less back where it belonged that way.
The problem is that aluminum has no "memory" and it stretches easily -- very hard to get the material back where it was.
mike
Old 04-19-2007, 07:29 PM   #3
JimGolden
JimGolden's Avatar
Profile:  1977 31' Excella 500
Tow it down to your local airport with a maintainence shop and get one of the airplane guys to look at it. A good shop will have some sheet metal guys that know aluminum. That'd be your best bet.
- Jim
JimGolden is offline   Reply With Quote
Old 04-19-2007, 07:29 PM   #4
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
Hey it's an ARGOSY!
Do the plunger trick, use smaller suction cups if needed (the kind window guys work with are great), then finish it off with bondo and PAINT ! You lucky dog!
Paula
Today is a gift. That's why they call it "the present"
Foiled Again is online now   Reply With Quote
Old 04-19-2007, 07:31 PM   #5
JimGolden
JimGolden's Avatar
Oh yeah, I forgot. Like Paula said. Argocy's have steel end caps
- Jim
Old 06-12-2007, 02:03 PM   #6
gergstuff
I tried the suction cup method but they did not have enough strength to pull out the dents. I will have to take a different approach.
Craig
Old 06-12-2007, 03:16 PM   #7
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
I found an industrial suction cup that was meant for automated lifting equipment. It has screw fitting in the center with a brass fitting where you hook a vacuum line. I have a small vacuum pump and rigged the setup so the pump would pull a vacuum on the plunger, then I pulled the hose and boing! out came the dent. This was on a SOB RV but the principle is the same.
It won't do anything for the creases...
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 06-13-2007, 02:44 PM   #8
remcolent
Profile:  1986 32' Excella
vledder , drenthe
YouTube - Car Dent Removal with Hair Dryer and Compressed Air
anyone used this trick on an Airstream?
remcolent is offline   Reply With Quote
Old 06-13-2007, 03:07 PM   #9
Pop Rivet
Pop Rivet's Avatar
Profile:  Salt Springs , Florida
Originally Posted by gergstuff
Hi,
Gergstuff
I had a similar problem and I just capped over the dents.
Pop Rivet is offline   Reply With Quote
Old 06-13-2007, 05:52 PM   #10
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
For me a Ding King or Pops a Dent works better than suction cups
Having more fun than a jack rabbit at a coyote picnic
Old 06-14-2007, 09:16 AM   #11
gergstuff
I watched the you tube video, interesting, not sure how well that would work on Aluminum. As someone had previously pointed out, Aluminum doesn't have the "memory" that sheet steel has.
I recall seeing the advertisements for the ding king and pops a dent, that might actually work, I will see if I can find one and give it a try.
Of course, I will advise as to the results (or lack thereof).
Thanks to all for the help.
Gerg
Old 08-22-2008, 02:17 PM   #12
gergstuff
Looks like I forgot to advise how this went. I tried the Ding King and it works sort of. I made larger dents into smaller dents and really need to get back into the project but I got sidetracked with a bunch of other stuff. I also need to get more dent pulling discs as it is pretty time consuming to do one dent at a time due to the length of time needed to wait for the glue to set etc. Ultimately, I think it will do a decent job but will still be a little wrinkly. I hate to use filler but that is likely the only way I can smooth things out.
Craig
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 02:31 PM
Dent Removal uwe Ribs, Skins & Rivets 7 11-14-2004 09:15 AM
Dent Pullers wagsrp Ribs, Skins & Rivets 8 10-18-2002 10:37 PM
Wardrobe Removal ??? 54FlyingCloud General Interior Topics 1 07-25-2002 02:22 PM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
