Old 11-15-2009, 07:15 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Damaged Argosy End Caps
How hard is it to deal with damaged Argosy end caps. Because they are steel, will they be harder to work with. Looking at an Argosy with basketball size dent in front end cap. Will taking off inner skin and going after it be the way to go? Thanks for the advice in advance.
Roadrunner is offline   Reply With Quote
Old 11-15-2009, 07:25 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
PAINTED Argosy = EASIER!
Painting can cover Bondo - not even an option with an Airstream. With an Argosy you can get "close", then use a bit of filler to take out the last visible imperfections prior to painting. With an Airstream there will always be some residual crease marks left.
Steel endcaps - are like a car body - so call your local dent removal service, and have them give it a go. They'll probably want to pop a few rivets on an inside panel and use some roller tools to pop the dent back out.
You could also remove the inside panel, then do the underinflated basketball trick, but steel might be a bit more stubborn than aluminum to pop back into shape.
Paula
Old 11-15-2009, 07:26 PM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I would think it would be easier than aluminum to deal with (no first had experience here). I've done my fair share of body work, but with steel you can use some heat to shrink any stretched areas. From behind might be easier, but you might see if someone has a spot weld dent puller. I presume you'll be repainting the area? If so you can borrow or rent one of those, they basically spot weld a little pin onto the dent, then you use a slide hammer to pull the dent. I'm sure there is someone on here that's done Argosy end caps that may have better advice though.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-15-2009, 07:35 PM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Yes do plan on painting it...RED, WHITE, and BLUE!
Old 11-15-2009, 09:17 PM   #5
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Simply fix them like body work on a car... and paint! Uses a dent puller to pull out the dent fill with bondo, sand, prime, paint....
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 11-16-2009, 05:48 AM   #6
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Hi Bob, I have done auto body repair for 32 yrs. and repainted 2 Argosy's and had dents in both of the trailer end caps. If it is just hail damage just fill with bondo prep and paint, if you start heating and trying to drill holes and pull them out you are going to have a lot of problems. The only way I would do anything else is if the dent was deep enough to cause interior damage and then take the interior panels off and push it out from the inside.
Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 11-16-2009, 06:49 AM   #7
1979 30' Argosy
Bob, There is something else I should have said, you might already know, be sure to use a good etching primer, DuPont makes a good one called DTM direct to metal. I would sand the cap and clean the hail dents out good with a wire brush on a drill and prime the whole cap then sand where your going to put bondo just enough to ruff the primer do not sand through the primer then bondo and prime with a high build primer.
Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 11-20-2009, 10:46 AM   #8
Squid's Avatar
1979 Argosy Minuet 6.7 Metre
I have a lot of dents in the body of my Minuet. Can you use bondo on the aluminum?
Squid
Captain Squid
Squid is offline   Reply With Quote
Old 11-20-2009, 10:53 AM   #9
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Yes...scuff it really good so that it will stick.
Hold the putty knife up straight to avoid excess
build up.
kennethowens is offline   Reply With Quote
Interior End Caps bill.johnson Floor Finishes 4 09-26-2009 10:08 PM
Interior end caps IndyAnne 1959-69 Tradewind 8 09-07-2008 10:17 AM
Cracks in end caps? Anniedog General Interior Topics 8 05-30-2008 09:00 PM
2 panel end caps??? byamcaravanner Off Topic Forum 1 02-03-2008 09:34 AM
interior plastic end caps catson4 Interior Restoration Forum 1 01-05-2008 06:30 AM
