Old 08-03-2007, 07:56 PM   #57
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
I put in new power ports for the 110 volt and ran a wire to the front and put one there for use with the generator.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 08-16-2007, 05:12 PM   #58
1979 30' Argosy
At some time I think someone backed the trailer under a low tree. I had to remover the rear curved part of the interior to knock out the dents. Wasn't as bad as I thought it would be. Also got all the insulation back in place. I used Roxul, it dosen't itch, dosen't hold water, and mice don't like the tast of it
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 08-22-2007, 08:16 PM   #59
1979 30' Argosy
All of the walls are back together and ready to some spot cleaning that we couldn't get to before and then painting.
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 08-22-2007, 09:39 PM   #60
1979 30' Argosy
Painted walls done
Well folks the previous post was of the master riveter at work... ... and the painting is complete of the walls...
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 08-26-2007, 05:50 PM   #61
1979 30' Argosy
Electric is all done. Annie's brother is an electrician and gas fitter, so I had him hook up everything. The small relay between the automatic transfer relay and the braker box is for the battery disconect.
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 08-26-2007, 07:23 PM   #62
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Hmmmm, do I still see POR 15 on that master riveters arm?
Great looking wiring job guys. You are moving along quite quickly.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 08-26-2007, 07:50 PM   #63
1979 30' Argosy
I put a light behind the steps, when I get them rebuilt, painted and re-installed they should look pretty good.
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 08-26-2007, 07:54 PM   #64
1979 30' Argosy
We got the floor installed this week, we used this flooring in our other Argosy and liked it so much we wanted it in this one.
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 08-26-2007, 08:45 PM   #65
aluminauti
whitelight's Avatar
Where we , Park it!
Happycampers - really neat job on the electrical wiring!
BTW, what brand/type of flooring did you install?
Lookin' good!
whitelight is offline   Reply With Quote
Old 08-27-2007, 06:48 AM   #66
1979 30' Argosy
Flooring
Whitelight.... Thanks for the compliments... The flooring is click laminate from Armstrong .
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 08-29-2007, 06:22 PM   #67
1979 30' Argosy
All of the partitions are painted and back in place and the spice rack up in the kitchen, fridge will be next thing in tomorrow if I can get some help to get it in the trailer.
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 08-30-2007, 06:49 PM   #68
1979 30' Argosy
Today I got the frig. in, not hooked up yet but close. I seen a good idea posted on this forum by Overlander 63 about putting extra insulation between the frig. and the pantry. Thanks Terry I think it will work very good. Last week I raised the fresh water tank 1/4 in. and that let it slide forward 3/4 in. and then I removed the drain valve, that saved 1/4 in. which gave me an extra 1 in. that I need very much when I put the couch in on the curb side. I will put a valve on the discharge side of the pump to drain the tank with.
Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 08-30-2007, 07:39 PM   #69
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Wow guys you have us impressed to no end!!!
Send that man of yours Annie and your brother for that matter up to the woods will ya!!!
Great job you guys - looks like you got all the reall hard stuff done - and with all the wood work being done to by your brother - you should be well on your way putting things back in time for your trip south - but if you want to stay up here in the cold Peter and I will keep you busy playing cards for sure!!!
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 08-30-2007, 07:42 PM   #70
SwampBillies's Avatar
1972 31' Sovereign
1964 24' Tradewind
Plant City , Florida
Send a message via AIM to SwampBillies
Wow! It looks fantastic! This is the fun part, seeing it all come back together.
Never argue with an idiot. They will drag you down to their level, then beat you with experience.
Debbie & Lewis Adkins
WBCCI #15754 --- AIR #18873
1972 - 31' Sovereign International (Betty)
1964 - 24' Tradewind (Glory)
2002 Ford F250 Super Duty
SwampBillies is offline   Reply With Quote
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 08:01 PM
Waxing the finish Joan D'Andrea Cleaning, Stripping & Polishing 15 01-05-2003 06:32 AM
Very rough finish lenny Cleaning, Stripping & Polishing 9 11-11-2002 06:42 PM
Fixing a scratch on a brushed finish? acwdgw Cleaning, Stripping & Polishing 3 10-22-2002 02:27 PM
WD-40....will it harm the finish? Chuck Exterior Restoration Forum 1 07-05-2002 10:50 AM
