Old 04-25-2010, 05:29 PM   #1
1977 Argosy 22
wildomar , California
correct tire size
Hi All,
First timer here.
I need to replace the tires on my 1977 22' Argosy. What size tires do I need. Will be towing it from So Cal to Or?
Laurie
contenteme is offline   Reply With Quote
Old 04-25-2010, 05:57 PM   #2
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Welcome Laurie, The tire size that came on your trailer was 7.00X15 We have Yokohama tires they are a different number but they say 7.00X15 on the tire and they are very good tires.
Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 04-25-2010, 07:58 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Radials
I'm running 225/75R15 radials on the Overlander. I blew a tire in the middle of nowhere Idaho and the nearest shop didn't have the right bias tires. All the tires were old, so I went for a total replacement. These tires seem to run fine. They are labeled "trailer service only" and are D rated. By the way, this shop was in Idaho Falls and they were nice enough to offer to put mount one tire and put it on the trailer to fit check it. We did a couple measurements and the radial replacement seemed almost a perfect fit.
I think it's a good idea to think about switching to radials for one reason--you won't often find a shop with bias ply D rated trailer tires in the right size. I think you have a better chance of finding a replacement radial, and one that has a DOT date less than a year out.
Zep
Old 04-25-2010, 08:17 PM   #4
1979 30' Argosy
Laurie, The Yokohama number is YR215 it is a radial light truck tire with a D rating. Toyo also make a good tire for your trailer.
Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 04-25-2010, 08:25 PM   #5
larry b's Avatar
1975 31' Sovereign
howell , Michigan
I just put on 225/75R16" Goodyear Wranger HT, I to had the old bias ply and wanted to run a radial tire the same size as possible. the 225/75 15" is about 1" shorter than the original. By switching the wheels and going to 16" I was to keep the same height. More money with buying new wheels but I personally didn't want to reduce my ride height.
7.00 X 15 bias ply ouside diameter 29.3"
225/75R16" outside diameter 29.3"
225/75R15" outside diameter 28.3"
Goodyear Tires | SUV and Truck Tires | Wrangler HT
Hope this helps
Larry
larry b is offline   Reply With Quote
Old 04-26-2010, 07:41 AM   #6
1975 31' Sovereign
1977 23' Safari
Originally Posted by larry b View Post
... I personally didn't want to reduce my ride height.
Excellent insight. I was only concerned at the time about the width fit in the wheel well. I never thought of the height, which is more important the longer the Airstream is. The good news is that I've gone over some pretty bad humps into gas stations, etc, with the Overlander and not dragged the tail end yet.
Now if the bolt pattern on my TV and the Airstream were the same (they are not), going to 16" wheels would allow just one spare...
Zep
Old 04-18-2012, 02:23 PM   #7
1971 29' Ambassador
guyton , Georgia
1971 29 ft need 4 tires is radial better than bias for towing
r.swanson is offline   Reply With Quote
Correct size bolts for floor? Lothlorian Repairing/Replacing Floor &/or Frame 16 12-09-2012 06:44 PM
Correct size fuse for 12V circuits FLYNCLD Batteries, Univolts, Converters & Inverters 7 04-23-2009 06:39 PM
Correct Tire Selection Glorette Tires 18 05-31-2007 09:40 PM
What is the correct bearing size for a 1962 toastie Axles 16 11-02-2006 11:49 PM
Correct tire pressure Centerfielder Tires 16 06-21-2004 07:15 AM
