Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 11-17-2007, 03:09 PM   #365
juel
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
I've taken some pictures of my 78, 24ft Argosy with the front couch. There is a piece that fits down on the street side, resting on the floor and over the pump and 12V outside light and pump wiring (I think). On top of that is another piece that rest on top of that and is the arm rest. On the other side (curb side) there is just a wooden shelf and no real arm rest. Hope these pictures help.
ID:	49435  Click image for larger version
ID:	49437  Click image for larger version
juel is offline   Reply With Quote
Old 11-17-2007, 03:34 PM   #366
SmokelessJoe
SmokelessJoe's Avatar
Profile:  1976 Argosy 24
TORONTO and Southwestern , Ontario
Thanks, Juel.
I think this confirms that the factory design was a higher shelf/arm rest curbside and a lower padded, removable armrest street side.
I’m not sure yet whether I’ll keep mine like that or raise the street side one to match the height of the other.
Some of the wiring you speak of will be to the water pump but most of it will be the cord coming in from your tow vehicle battery and splitting off, through circuit breakers, to various auxiliary circuits such as brakes, clearance markers, turn signals etc.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 11-18-2007, 10:06 AM   #367
SmokelessJoe
Back to rock guards...
Gary,
Re your cost/benefit analysis on buying rock guards or paying to replace glass:
I received a quote of $661.oo from Oasis RV. Did you pay less someplace or are you factoring in the cost to install a new curved window?
Or maybe you’re dividing the cost of the Guards by three windows?
Please explain how you arrived at the comparison.
Still considering,
Sergei
Old 11-18-2007, 11:01 AM   #368
Janet's Husband
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
Originally Posted by SmokelessJoe
Gary,
Still considering,
Sergei
Sergei
I want to claim "stupidity" The rock guard did cost $650, Janet just found the receipt. Somehow, I got it in my mind it was $350, sorry for that.
Well now, you can still look at the overall cost of the curved glass and the installation cost of the glass. Rivets, sealant, new touchup paint... Also an item to take into consideration is you can't just order the glass from what I understand. I would think that a busted window would put a big damper on ones attitude.
In my opinion it is still worth the cost for the peace of mind you get from the extra protection. I will be putting them on the 77 Rear Door they just look too good not to.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 11-22-2007, 09:59 PM   #369
SmokelessJoe
How do I get the screen door off?
Last summer we put a window that I got from Balgrn into the Argosy door.
I’ve decided now that I want to make the door window fully operational, permanently replacing the screen door.
I can’t readily see how the main door hinge-pin comes apart.
The rivets could be drilled out of the screen door hinge but I would like to remove the entire screen door, including the hinge supports.
Information much appreciated.
Sergei
Old 11-23-2007, 08:38 AM   #370
Argonaut20
Profile:  1978 Argosy Minuet 6.0 Metre
Las Cruces , New Mexico
We lost an "unbreakable" street side window due to a rock and I can tell you that you don't want to replace it if you don't have to. Thanks to Balgrn, we got a clear window for less than the $500 a new one would cost, and the new ones are tinted from what I understand. Clear windows are collector items. The fun begins when you realize that Argosy trailers are somewhat idiosyncratic so the replacement window doesn't quite match the shape of YOUR Argosy. Lots of drilling, fitting, caulking, riveting (as well as screws - didn't want to say screwing), and repainting make that preventive rock guard a great idea. All it takes is a big enough rock perpendicular to the front of the trailer and the side window is toast. Rare, but it happens.
1978 Argosy 6 Metre Minuet
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 11-23-2007, 09:03 AM   #371
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
The one piece rock guards for 70's Airstreams go for around $350. The ones for the Argosy's are 3 piece and cost a bunch more. From what I read, those wing windows are worth protecting.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 11-23-2007, 02:07 PM   #372
SmokelessJoe
Rock Guards, continued
OK, we’ve had some real life experience and opinions form Juel, Whitelight, Mistral Blue, Marc, Janet’s Husband, MotorSeven, Happy Camper, Bob, Argonaut and Azflycaster.
I’m still curious to know how wide the prevalence of actual broken front windows is out there.
Here’s a poll we’re taking:
http://www.airforums.com/forums/f469...ors-37715.html
Argonaut, was it your FRONT, curved street side window that took the hit?
Perpendicular. Does that mean the rock bounced straight up from the road surface?
Thanks for the stories and opinions.
Sergei
Old 11-23-2007, 05:43 PM   #373
Argonaut20
Front curved streetside window took the hit from a rock that struck directly from the front, perpendicular to the front, likely thrown high from a passing vehicle. Think of something that could have traveled over the top of the tow vehicle, not necessarily up from the road from the rear wheels. Striking point about 2 inches from the right hand edge of the window (viewed from back), about 4 inches below the top. Obviously the worst kind of rock hit as it was not on the curved surface and all force gets translated to the window. This is not a common strike, but anything that hits that window normal to the surface it strikes is likely to break the window.
2006 Toyota Tacoma
Old 12-02-2007, 08:32 PM   #374
mrmossyone
mrmossyone's Avatar
Profile:  1975 Argosy 24
Collierville , Tennessee
I have been seriously thinking of making my own rock guards out of sheet metal. Cut them minus a 1/4 inch to the shape of curved window place padding ( I think the foam weatherstripping would work very well)at points that could contact window and use the brackets that are used to hold the plexiglass style rock guard that is on my middle window. You would just slide the sheet metal into position in bracket and snap the holder on bracket over the sheet metal holding it in place. I plan on painting them to match the theme or colors that I have been painting the Argosy. They are only for travelling and I think I can make them look pretty good for probably about 25 bucks a piece. What do y'all think? Has anyone tried this approach?
Different strokes for different folks!
I never learned from a man who agreed with me.
Heinlein
mrmossyone is offline   Reply With Quote
Old 12-09-2007, 12:09 PM   #375
SmokelessJoe
I need a better camera
The furniture DavidsonOverlander made for me looks much nicer in the trailer.
ID:	50541Click image for larger version
The fold out table is covered in matching Marmoleum, as is the kitchen counter (and floor).
The grey wool upholstery will be made and delivered after Christmas.
The backrest shelf under the window easily lifts off it’s brackets if the sofa is used for sleeping.
I picked up that tip from reading complaints about a fixed shelf on the forum.
Sergei
Old 12-09-2007, 05:21 PM   #376
SmokelessJoe
ID:	50573There are 8 Xenon down lamps through the coach.
Name:	front dimmer.jpg
The 12v dimmers are by Frilight of Sweden. The front 4 are controlled at the entry door.
Name:	mid dimmer.jpg
The back 4 are dimmed at a midship wall.
Old 12-10-2007, 10:45 PM   #377
safari62
safari62's Avatar
Profile:  1962 22' Safari
Vacationland , Maine
Images: 44
12v Dimmers
Nice touch S-Joe. Where are this available?
Gary
Also, is that a floor Marmoleum product used on th table or another product?
safari62 is offline   Reply With Quote
Old 12-11-2007, 01:58 PM   #378
safari62
safari62's Avatar
Images: 44
Guess I sould not ask a question at a late hour judging by the spelling, grammar and missing letters. wow.
Anyway I was curious about the 12v dimmer and if the table surface Marmoleum is the same as the flooring.
Nice work.
Gary
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 7 06-20-2007 12:18 AM
Argosy Motorhome Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 09-26-2006 06:21 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 10:36 PM
Looking for a stone guard -1976 Argosy James Martin Rock Guards, Segment & Window Protectors 5 11-28-2005 08:49 PM
