The current drain is in the way of my new furniture install.
Since I’ve installed a shut-off between the pump and the tank can’t I just cap off the existing drain?
Sergei
I'd hate to see anything interfere with the new furniture , but I think a drain is a good idea. When we use our trailer for the last time before winterizing I open the drain before we head for home. That gives lots of time for as much water as possible to run out. I also remove the pump and store it indoors. In the winter you'll probably be heading south to some place where the temperatures will be well above freezing while our trailer sits in the snow, but I still think a drain is a good idea if you can fit it in.
Grant Davidson
Milton, ON
1964 Overlander
2005 F-350 SRW 4x4 crew cab long box
1965 Avion C-10 Truck Camper
One of the things that bugged me about the original Argosy was the lack of attention to details. Every time you opened a door or peeked behind or under something, it seemed unsightly: unfinished plywood, jagged metal or protruding screws.
No more musty corners. Everything “factory new” or better.
Post #176 showed how we hung the LG Art Cool split air blower unit on the wall between the bath and mid ship bedroom.
I covered the access opening that we had to cut to route the A/C supply lines through the pocket door wall with a brushed aluminum panel, glued on with PL Premium.
Finished, it now looks as if were always a part of the LG unit.
It’s really nice to have the workspace cooled now, like a reward for all the effort.
I’d like to go with a new roller blind I saw at IKEA called Tupplar.
They come in three nice colours – khaki, midnight blue and white – and have a blackout lining.
I plan to use them on all the windows, including the centre one in the front wrap around. I will try to use the existing rails for the wrap around glass portion and see if Ching Mei can make me those curtain panels from left over Tupplar material.
The only other fabric in the trailer is on the two gauchos, front and mid-ships. They will be upholstered in a GM Oldsmobile Cadillac specified woolen called Dorchester Grey.
Who is the manufacturer of the cooktop? I don't think I've ever heard of or seen a diesel fueled cooktop. Is this specifically designed for RV use? Very cool.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
