Old 08-18-2003, 07:39 AM   #1
mkeith54's Avatar
1976 26' Argosy 26
New Florence , Missouri
Send a message via AIM to mkeith54 Send a message via Yahoo to mkeith54
Condensate Drain
I know that the Airstream Trailes have a condensate drain from the A/C unit down throught the wall to ground level. Is there a darain on the Argosy's as well? If there is where does it exit under the trailer? We have a 26' from 1975. Thanks
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
mkeith54 is offline   Reply With Quote
Old 08-18-2003, 08:41 AM   #2
Chas's Avatar
Images: 22
An Argosy has the drain just like the Airstreams. Look for a small hose stubbing thru the belly just in front of the wheels on the streetside. It will look just like a multitude of other hoses going thru so it may take a bit of detective work, differentiating it from the rest, the low point water drains, overflows, etc.
Chas
Chas is offline   Reply With Quote
Old 08-18-2003, 10:12 AM   #3
mkeith54's Avatar
1976 26' Argosy 26
Thanks Chas, as soon as it ccols down a bit outside I'll look for it.
Mike
Mike Keith
75 Argosy 26'
Old 08-18-2003, 02:01 PM   #4
Lee Pace's Avatar
Condensate drain
Mike,
We also have the same problem! We have a 69 Overlander. I will look again for the drain hole. My husband has looked to no avail.
Gloria Pace
69 Overlander
WBCCI 7287
Lee Pace is offline   Reply With Quote
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
Water leak from Holding Tank Drain gwilliam Fresh Water Systems 5 04-18-2010 06:45 PM
AC drain location markdoane Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-17-2003 06:33 AM
'70's condensate drain? john hd Furnaces, Heaters, Fireplaces & Air Conditioning 12 04-16-2003 07:05 PM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 05:33 PM
