Old 01-15-2012, 07:16 PM   #1
1979 Argosy Minuet 6.7 Metre
San Antonio , Texas
City water
Does anyone have a picture of an original city water hookup?
My '79 has a "few extras" attached and part of the copper line is kinked.
Just wondering what it should look like.
Thank you!
Vicki A. is offline   Reply With Quote
Old 01-16-2012, 08:19 AM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Sorry no pics, but the water supply on my Minuet came in the back, elled into a line that had a pressure regulator and a check valve before the line continued on to supply the water to the fixtures and water heater. The check valve was to keep the water from dribbling out when using the on board pump while the pressure regulator was to protect from high pressure connections when at a campground or tied into city source.
While pex is good for distribution, the check valve - pressure regulator assembly is heavy enough that I left it in copper for strength.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Need advice on removing City Water Fill on 1994 Limit Don McKelvay Fresh Water Systems 2 11-01-2011 10:47 PM
My toilet won't flush on city water godaddy64 Plumbing - Systems & Fixtures 12 09-18-2011 02:37 PM
Fresh Water Tank and City Water ??? tr0y Fresh Water Systems 3 08-29-2011 04:49 AM
Proper City Water Fill, 30A inlet, etc. Placement? worldinchaos General Repair Forum 5 08-16-2011 02:39 PM
Water coming out city water inlet mutcth Fresh Water Systems 5 05-27-2011 09:23 AM
