Originally Posted by Dan S
My interior does not have the crank, just the small plastic disc that surrounds the crank mechanism. The surround has three small phillips head screws and it appears that one is backed out a bit and the plastic ring is not sitting flush with the celing. Should I just try screwing it back in?
Dan
There is a couple O-rings in there, they may be dried out, If it is like what I had, holes in the cast alunimum base, you'll never get it sealed... It just kept seaping in. My antenna was removed by the PO. Just the base as left.
Here is a pic of the assembly
