Old 03-25-2007, 09:52 AM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Checking TV antenna for leaks
How do go about checking? Would there be seal there that appears bad? Or, do I need to simply cake on some sealant anywhere there is a roof penetration or seam?
Let the games begin.
Dan
Dan S is offline   Reply With Quote
Old 03-25-2007, 10:27 AM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Check this out, may give you some insight.
Leak
I capped mine off.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-25-2007, 12:56 PM   #3
Dan S's Avatar
1975 Argosy 26
my antenna crank
My interior does not have the crank, just the small plastic disc that surrounds the crank mechanism. The surround has three small phillips head screws and it appears that one is backed out a bit and the plastic ring is not sitting flush with the celing. Should I just try screwing it back in?
Dan
Old 03-25-2007, 01:16 PM   #4
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Dan
There is a couple O-rings in there, they may be dried out, If it is like what I had, holes in the cast alunimum base, you'll never get it sealed... It just kept seaping in. My antenna was removed by the PO. Just the base as left.
Here is a pic of the assembly
www.balrgn.com
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 11:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 02:30 PM
TV Antenna lead fdx753 Audio, Video & TV 14 04-27-2004 09:45 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 12:34 PM
