Old 06-13-2014, 08:43 PM   #1
BentMetal's Avatar
1972 Argosy 26
Alamogordo , New Mexico
Cheap @$# Wheel Wells
Those original plastic wheel wells on my '72 Argosy 26 are so flimsy that I'm afraid if a tire blew out, part of my interior would go as well. Has anyone ever replaced those? If so, where did you get replacements? Also, I don't need to do a frame off restoration, and the floor is excellent from the wheels back. I am replacing floor under the refrigerator area due to a past leak issue, so I can get to the wheel well part of the frame on the street side of the trailer. My Argosy has the full bed layout. Any advice would be so welcome. I am replacing parts of the floor from up to the wheel well and forward, or therabouts.
BentMetal is offline   Reply With Quote
Old 06-13-2014, 08:52 PM   #2
r carl's Avatar
Lin , Ne
If you plan on running st tires you just as well make new wheel wells now out of 1/4" boiler plate.
Old 06-13-2014, 09:05 PM   #3
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I've heard of some getting wheel wells made out of sheet metal. Try taking your old wheel wells to an HVAC shop and they should be able to fabricate some up for you.
desertair27 is offline   Reply With Quote
Old 06-13-2014, 10:52 PM   #4
BentMetal's Avatar
1972 Argosy 26
Thanks! I like the idea of having them fabricated.
Old 06-14-2014, 07:24 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sheet metal will not be heavy enough to prevent damage. The typical stock trailer has 12 gauge metal for fenders. I have seen them ripped completely off with a blow out.
My thought has always been to build fenders out of 1/4" material and incorporate a device on the rear and outside edge of the fender to shred the tire as it flies apart. Thus preventing it from whipping and doing serious damage to the trailer skin.
Even though the fenders would be a lot heavier than the plastic. Preventing damage is my main concern. The little bit it would cost in fuel would be offset by not having a big $$$$ repair bill.
Just thinking out loud.
Old 06-23-2014, 09:28 AM   #6
BentMetal's Avatar
1972 Argosy 26
Maybe the originals aren't so cheap after all. As I pulled out flooring near the wheel, I noticed there is another wheel well under the beige plastic. I'm thinking the beige plastic was just an interior thing so you're not looking at the ugly, black wheel well. However, as I tear into this trailer, I'm finding things that make me think it's been worked on before, so I'm not altogether certain of what's original…. more on that in another post.
Old 06-23-2014, 07:09 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Believe the original were double layer plastic with fiberglass batt insulation between the layers.
Aaron
WBCCI #XXXX AIR #2495
Old 06-26-2014, 10:50 PM   #8
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
my argosy had a blowout before I purchased it. the fender is still one piece. chewed up the fender trim and outer skin though.
AlbertaBound is offline   Reply With Quote
Old 06-27-2014, 12:01 AM   #9
1974 Argosy 20
Kooskia , Idaho
That two set wheel well was standard, one inside one outside, insulation in between. And they were made 42 years ago, so might not be too flimsy .... The ones on my 74 are still doing very well.
sealing seams in the wheel wells.. safari25-05 Wheel Wells 6 01-16-2007 03:38 PM
Wheel wells question cameront120 Roof 4 06-11-2006 10:41 PM
Leaky wheel wells TomW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-25-2005 01:00 PM
Plastic Wheel Wells Dennis Interior Restoration Forum 14 01-17-2003 12:05 AM
