Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 07-14-2008, 03:34 PM   #1
granaudio
Ruben
Profile:  1977 Argosy 24
Monterey County , California
Cap-off fridge gas-line fitting
I dis-connected my elect/gas fridge in my 77` 24` rear-door & want to cap off the end of the gas-line that comes in thru the floor to connect to the Dometic RM66 fridge male-end fitting,
does anybody know what fitting & size I can use to cap-off the female-end?(I won`t be using the gas-line). I tried a few fittings from home depot but none fit or worked.
also while I`m on the subject of copper lines,
how would run drain all the lines in the water system if one wants to solder/repair or replace some copper water-line tubing?
could this only be done by releasing both grey & black-water tanks?
or is there drains thru the floor at each fixture?
Last edited by granaudio; 07-14-2008 at 03:43 PM. Reason: Similar subject question
granaudio is offline   Reply With Quote
Old 07-14-2008, 03:44 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
I think it is 3/8" flare fitting type plug. It should take a 3/4" wrench to tighten.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 07-14-2008, 03:58 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
You shouldn't need to drain either waste tank to work on the water lines. Today's models all have low point drains that let you drain the water, especially important for winter draining.
Non-contributing deadbeat.
Old 07-14-2008, 04:21 PM   #4
granaudio
Ruben
Thank`s to both of you!
I`ll try the 3/8" fitting & look for some low point drains.
Old 07-16-2008, 07:19 PM   #5
granaudio
Ruben
3/8" flare fitting worked & the low drain points(on mine) were underneath/behind my bathroom closet.
Thank`s all!!
Locking Gas Cap for 2003 AS Gas Motorhome spat61 Land Yacht/Legacy Motorhomes 10 06-22-2008 08:45 PM
Bowen gas line fitting?? PeteL Water Heaters, Filters & Pumps 3 03-21-2008 07:05 PM
1/4" Compression fitting for air suspension line philippes General Motorhome Topics 4 03-17-2007 08:51 PM
LP gas line question 63air LP Gas, Piping, Tanks & Regulators 5 01-21-2007 09:41 PM
Gas Cap for 1989 MoHo noiva Mechanics Corner - Engines, Transmission & More... 5 08-25-2006 07:08 PM
