Old 10-05-2010, 01:41 PM   #1
RV H-D Lady's Avatar
1976 Argosy 24
sun city , Arizona
Can't get the shower pan out
The drain is removed and it appears to be loose all around the top lip, but it's acting like it's glued or some how stuck to the floor. Is that possible?
RV H-D Lady is offline   Reply With Quote
Old 10-07-2010, 06:09 AM   #2
1976 Argosy 24
sun city , Arizona
I guess they ARE glued down. I found this thread.....
http://www.airforums.com/forums/f446...val-22414.html
Old 10-07-2010, 08:26 AM   #3
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
May I ask why your taking it out?
kennethowens is offline   Reply With Quote
Old 10-07-2010, 06:09 PM   #4
1976 Argosy 24
sun city , Arizona
To replace the rotted floor beneath it.
Old 10-08-2010, 07:05 AM   #5
1975 Argosy 24
Malakoff , Texas
Follow up to my question:
Hmmm.....chisel and cut(the wood) and take the wood and all out at the same time.
You may have to drill a couple of holes beyond the perimeter to use as start points.
Once out, ya can clean the old adhesive off and have it ready for a first
class repair.
Old 10-08-2010, 08:05 AM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
What shape is the pan in an Argosy - curved/square? May be able to find a replacement. Othewise, can you get under a leading edge at all? May be able to separate it slowly using a razor scraper:
QEP 4 in. Razor Scraper - 62900 at The Home Depot
Old 10-08-2010, 02:55 PM   #7
1976 Argosy 24
sun city , Arizona
My Argosy shower is up against the back corner so it has a curve in it. It's not one of those nice squared corner, easy to replace ones. I'm going to try the method in the link I posted in my response #2. I bought a 3' x 1/8 X 1" wide piece of metal. I'm going to hammer to wedge it under the pan and hopefully scrape up the glue in the process. That's tomorrow mornings project. I'll report on my success or failure. = ) Cutting out the floor with the pan attached might be fun though.
Old 10-08-2010, 05:50 PM   #8
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
post some pictures
Sally, I went thru your posts....I got lost as to when you got the Argosy. Reference your thread.....http://www.airforums.com/forums/f44/...89.html....and my post #11. Did you get this Argosy at Oasis? Did you have any indication or warning of the job you were taking on. Regardless, just keep at it and finish it up ....you will, WILL, appreciate the results. I just hate to see the things you now face. Lots of help here.
Old 10-09-2010, 06:32 AM   #9
1976 Argosy 24
sun city , Arizona
Melody Ranch, I got the Argosy three weeks ago in Oklahoma. And no, I wasn't aware of ALL the work ahead of me, such as the 4" deep of rotted floor across the back. I'm convinced Airstreams were built assuming nothing would ever break or leak or need repaired or replaced. I'm trying to remove everything that needs to be removed that I can remove myself, with plans to hire someone to replace or rebuild most everything that needs to be rebuilt or replaced.
The air conditioner is really good as is the heater, water pump, stove/oven, awning, axles, tires, brakes, cabinets, all tambors, cushions and upholstry, windows and screens (except for the gaskets). The water lines were all updated, the propane tanks are good, it has a brand new battery and good spare tire. All the tanks appear to be good, too.
It does get frustrating when I can't even remove a few rusty screws. When I hit a wall I go to a project that I know I can do, and that keeps me going. If I ever sell my Harley and my Toy Hauler I will have lots more money to put into the Argosy.
Thanks for your words of encouragement. I really appreciate it.
Old 10-09-2010, 05:54 PM   #10
1976 Argosy 24
sun city , Arizona
WAHOO!! I got the shower pan out. It only took one length of metal strip hammered under the pan, then voila, it popped up. And here's some pictures of what's underneath....... It's not a very pretty. Guess I'll put in a new black tank while I'm at it.
Name:	argpsy shower pan gone.jpg
ID:	112763   Click image for larger version
Name:	argpsy rotted floor2.jpg
Name:	argosy rotted floor.jpg
Old 10-09-2010, 07:17 PM   #11
tallytwo1994's Avatar
tallahassee , Florida
Yuck! But fixable.
Good Luck,
Carol
tallytwo1994 is offline   Reply With Quote
Old 10-10-2010, 08:09 AM   #12
Bex
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
How did you determine the floor was rotted?
Bex
Bex is offline   Reply With Quote
Old 10-10-2010, 07:40 PM   #13
1976 Argosy 24
sun city , Arizona
Bex
After I removed the toilet I found the base that the toilet had been sitting on was rotted out. when I removed all of that I could see behind the black tank and a small area behind the shower pan. The more stuff I removed the more rotted wood I found.
Old 10-10-2010, 08:25 PM   #14
Ottawa , ON
Here's another "how": How do you know your black tank is NG?
Custom Shower Pan Tom Bray Sinks, Showers & Toilets 20 04-30-2017 09:29 PM
Removing shower pan guy99 Classic Motorhomes 5 09-30-2011 09:10 PM
Anyone curious about what's under the shower pan? SafeHarbor 1978- 1979 Excella 500 7 12-13-2010 03:22 PM
Shower pan removal? glacierrunne Sinks, Showers & Toilets 2 07-02-2006 09:45 PM
64 Bambi II shower pan Pat McSween Sinks, Showers & Toilets 2 08-02-2003 02:53 PM
