10-05-2014, 06:40 PM
1979 30' Argosy
Jeddo
, Michigan
Camper has "ODORS" Help Please
I have an Argosy 30 and it is a stinker! When the camper is left closed for any extended period ( over a week or so)the smell is just obnoxious. We have scrubbed the entire interior, disinfected the fresh, black and grey water holding tanks, replaced all interior carpet and hard flooring and recovered all the interior upholstery. The floor was solid through out and I painted the sub floor with primer when I put in the new flooring. I am now wondering if water could have entered the area between the bottom of the sub floor and been trapped in the insulation between the bottom pan and the sub floor, where the camper frame is located? What would be the downside of removing and not replacing the pan metal and floor insulation? I am getting pretty frustrated with this problem after chasing it for about 1 1/2 yrs. any suggestions or solutions would be appreciated. Thank you in advance for any help.
10-05-2014, 07:01 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Definitely drop the pan and inspect, but it's not a good permanent solution. If there's water there, it's getting in from somewhere so find the leak. It's an easy fix if that's the problem.
Let me first suggest that you check the vent pipe for the toilet. If it's clogged anything left in the black tank will ferment and burp out through the toilet bowl.
Next, you mentioned re-covering all of the upholstered pieces. Old foam can break down and smell like ammonia, so I'd suggest putting the upholstered pieces in a shed or garage for a week - and if the smell moves you've found the cuplrit.
How about the batteries? Do you have them on a charger/battery minder? Remove them next time you store it, see if that changes anything.
Lastly - mice between the interior and exterior skin, and their droppings.... or just the carcasses of the departed ones can be pretty fragrant. Take covers off the outlets or loosen lamps from the inside skins and take a whiff.
Hope it's anything but the last one.
Paula
10-05-2014, 07:03 PM
2007 25' Safari FB SE
2000 30' Excella
1999 30' Excella 1000
Low Country
, South Carolina
We had a similar but not as bad situation. Since our unit was 07 we were surprised it had a smell. After doing what you had also done, we decided the only thing left was the zippered covers on the upholstered pieces. We took them off, washed them and then put them back on. No more smell. Maybe that is your problem. If the covers are not removeable, a good upholstery cleaner should do the job. Maybe not the problem, but it is something to try and you will have clean upholstery.
StreamNTyme
1963 16' Bambi
Stevens Point
, Wisconsin
Hey hardwood,
I didn't replace the insulation under the floor for that very reason. The old insulation was full of both dead mice and their droppings. Yuk!
Tim
10-06-2014, 05:50 PM
Eckville, Lacombe County
, Alberta
I went o look at a 19ft recently and could not identify the smell but the seller did say it was there when they bought it maybe 7 years ago. I decided to pass on the purchase. It was whilst I was driving home that I remembered when I had smelled that smell before. It was when cleaning a mobile home, the forced air heating vents were infested with (dead) mice.The smell is pretty odd, almost amoniated or similar (to me) to napthalene. Hard to describe but it might be mice. See if you can find an ozone machine to pop in there for 3 days. Keep the windows shut and dont go in there whilst its running. Shut the power off after the three days and then wait 5 or 6 hours before removing it.
If the small comes back you will know its in the walls or belly pan.
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
10-06-2014, 06:00 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
If the foam seal at the bottom of toilet is leaking or missing there might be a hidden deposit around and under the base of the toilet. My Safari had a funky smell when I got it. Someone had removed the toilet then re-installed it and did not get the foam seal placed correctly. I cleaned it up and installed a new seal. No smell since then.
Alan
10-06-2014, 06:10 PM
2019 27' Flying Cloud
Kansas City
, Missouri
any chance that a previous owner had a cat or dog that had accidents? If so there are enzymes that kill that smell.
Piggy Bank
10-07-2014, 07:11 AM
1979 30' Argosy
Jeddo
, Michigan
Wow, thank you all for your input. I have replaced most everything on the inside that would hold a smell. Checked all the gaskets leading to the holding tanks etc. etc. I am going to drop the belly pan and see what is going on in there. At this point I am either going to find the problem and remove/repair it or get rid of the trailer. Enough is enough I guess! I would like to inspect and repaint the frame anyway just to preserve it. We really like the old trailer and it pulls great so am hoping to find the problem. Again, thank you. Jeff
10-07-2014, 08:59 AM
1981 31' Excella II
New Market
, Alabama
These things tend to get smelly after a while. The fiberglass in the walls and under the floor tend to get moldy and smelly after a while. Rodents and bugs contribute to the problem. Also all the plastic stuff ages and out gasses as well. You could try an ozone generator but they can cause plastics to degrade even further if used too much.
Perry
10-07-2014, 09:45 AM
1972 23' Safari
1963 16' Bambi
1947 22' Liner
Hillpoint
, Wisconsin
I found mouse nests , dead mice ect.. in the underfloor insulation in my Argosy when worked on it. I also found the same in the walls and I know there is some behind the interior endcaps that I have not got to yet.
10-07-2014, 09:46 AM
1974 Argosy 20
Kooskia
, Idaho
Paula mentioned batteries, so be sure to check that possibility out. When they are being overcharged and are at the end of their life they give off a very strange smell, similar to dead mice. It is a possibility, anyway.
Then dead mice, then mold and crap in the underfloor insulation. My best three shots.
10-13-2014, 08:25 PM
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose
, Alberta
My gutted shell still stinks. The bottom 4 feet of interior walls and insulation are removed and aluminum washed repeatedly. All new subfloor, no insulation in floor yet. Looks like I need to remove the ceiling to find the smell. Good luck finding your odour!
10-13-2014, 08:40 PM
Ottawa
, ON
Did anyone suggest checking the black tank vent on the roof? If that gets blocked, the smell will build up pretty fast in the TT, and will NOT go away.
Get up on that roof (staying on the stringers that support it), and take the vent off, then run something down the pipe and make sure it is clear.
The vents need to be serviced every few years in order to stay clear. Leaves, birds, etc can get trapper in them making things stinky inside.
They are also a common source of roof leaks. You will need a new gasket, a piece of screen to keep leaves out, and a tube of Vulkem (I can't remember the new name for it, but someone here will tell you).
Anyways, check it thoroughly before doing anything else, it is a pretty simple repair, and probably needs doing even if it is not what is causing the smell.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
10-13-2014, 09:37 PM
1966 17' Caravel
Las Cruces
, New Mexico
Not to be too pessimistic, but I am amazed at how long odors stay even after all the insulation is gone from beneath the floor and in the walls. The Caravel is stripped inside and I swear I could still smell the mouse urine, mouse bodies, etc until very recently. Every panel for the interior is going to be scrubbed down before I put it back into the trailer.
1966 Airstream Caravel
2006 Toyota Tacoma
10-14-2014, 08:59 AM
1973 21' Globetrotter
Houston
So I have been completely rebuilding my trailer. The subfloor is brand new, the interior skins have been replaced with new material, all insulation has been replaced, and out of the blue--stank! Turns out the plastic interior end caps reek. After installing them once, the trailer immediately stank so much that I removed them, scrubbed them down with bleach, and reinstalled. The stank came back. So I have painted the interior surface of them, and that has helped a lot. Wish I had painted the outsides of them before putting them in the second time--just didn't imagine that clean plastic would still be so stinky. Soooo, you might want to just paint everything in sight! Should help. Oh, and your bellypan is surely full of nasty. You'll want to deal with that as well.
good luck!
10-14-2014, 09:42 AM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
My 86 stinks as well after being closed up for a few days. Wet days makes it worse. I've cleaned, reupholstered, urethane on the OSB subfloor, new cork floor covering, new foam board insulation under the sub floor, etc, etc. I did notice the plastic furnace vent to the bath smells bad, but it runs under the floor. Luckily the smell quickly dissipates and isn't noticeable when we are traveling in the trailer.
Our smell is plastic like. The wife says somewhat like a new doll at Christmas. Thanks for the tip in the plastic end caps. Maybe that's were it is coming from.
David
10-14-2014, 09:51 AM
1999 34' Excella
Hillsboro
Anyone try the 'Ozium' stuff? It is pretty rank chemically smelling, but it has been helpful for us.. I think this is similar to what they use in the Airline industry when they clean up the 'winged bus'.
Peace and Blessings..
Channing
WBCCI# 30676
10-14-2014, 11:31 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
A 1979 unit will almost certainly have been infested by mice at some point in its life. They will leave behind a copious amount of droppings and perhaps even a dead comrade or two (or a few dozen!)
Assuming you have checked out the commode and vent pipe as previously suggested, I would drop the belly pan, remove all the insulation and inevitable mouse remnants, clean thoroughly, do whatever frame repairs/strengthening you want to do, install new insulation and reinstall the belly pan. When you reinstall the belly pan, make sure to rivet the heck out of it to close up any little holes for mice to get back in! And check the rivets on a regular basis and fix as needed (rivets holding the belly pan always fail.)
If you still have a bad odor, then the mice have gotten into the area between the inside and outside skins. The only solution in that case is a complete gutting of the trailer which sounds like a bad deal for you since you have already restored the interior.
Best of luck to you!
Bob Martel
WBCCI# 5766
10-14-2014, 03:03 PM
1999 34' Excella
Hillsboro
if between the wall and exterior, perhaps a spray injected via a straw, like on a WD-40 can, perhaps you can diminish the odor?
Channing
WBCCI# 30676
10-14-2014, 07:23 PM
1981 31' Excella II
New Market
, Alabama
Alot of old plastic stinks as it ages. The combination of ozone and age and a little uv make for stinky plastic. I think a lot of my trailer stink is the old plastic. Sealing with paint is not a bad idea.
Perry
