Old 05-23-2009, 04:31 PM   #1
1977 Argosy Minuet 6.0 Metre
SPOTSYLVANIA , Virginia
camlocks
How do you install them-has to be an easy way. thanks
vcu70 is offline   Reply With Quote
Old 05-23-2009, 05:21 PM   #2
Campaz's Avatar
1987 23' Sovereign
Tucson , Arizona
Press the spring down on the wire or metal frame. The loop at the top can slide down to a point where the wire or metal frame is narrow. It can then be turned slightly and popped off. Be careful and release the spring slowly so it doesn't fly off. To install simply push the spring and wire or metal frame through the hole from the bottom, depressing the spring and re-install the top loop on top of the hole. Hope that makes sense.
Rick
WBCCI# 4652
Four Corners Unit
Campaz is offline   Reply With Quote
Old 05-25-2009, 07:24 PM   #3
done, so eaasy thanks
