I would be interested in seeing where your crank down stabilizers are mounted if you have a pic,or maybe a drawing?? My husband bought some of those & has never mounted them because we were not sure where they should go??
Here's pictures of the installation of crank down BAL stabilizers we added to our 77 Minuet 6.0 this year. We attached them to the frame of Scatter Bug - they are working out wonderfully.
__________________ Michelle & Leon
WBCCI # 7032 New England Unit
White Mountains NH Unit
Vintage Airstream Club Tin Can Tourists Vintage Club
Hmmm - I have been corrected by my husband-our to be installed stabilizers are called "scissor jacks". Would it be the same idea to mount. And could you tell where the frame was underneath? (we have not been wayyyy under yet)
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
It's the same install for "scissor jacks" as for BAL stabilizers.
The frame on our Mini is kind of like studs, every so many inches there is a support piece. We found them within minutes of banging around on the underbelly of Scatter Bug. I'm thinking yours will be the same.
Something to keep in mind with the scissor jack type stabilizers is that they typically will extend below the bottom of the rear frame horns that are designed to take the brunt of the force when the rear of the coach drags on pavement when encountering deep dips in the road surface. My first set of scissor type stabilizers were drug off of my Overlander because they were mounted too far toward the rear. Knowing the difficulty that I had with the scissor stabilizers on the Overlander, I went with the BAL stabilizers like the ones used on current Airstreams for my Minuet -- the coach has had pavement contact with the rear frame horns several times, but the BAL stabilizers have escaped unscathed.
Kevin
Kevin D. Allen WBCCI (Lifetime Member)/VAC/Free Wheelers #6359 AIR #827
I just picked up my Argosy. Inside is in pretty good shape. Body as well. The bathroom door is gone as well as the the sliding door under the sink. Holding tank leaks pretty bad, lot of rust on axel and around tanks ( I guess that is why there leaking). Any advice would be apprciated!
WELL, howdy there Squid - nice to have you and another 6.7! You are going to be soo happy & pleasantly surprised with you new very handsome Minuet. We have had our "Moonunit" for just over 5 yrs. Many friendly owners here to help you w/any ?? If you have trouble w/manuvering on site, let us know, its a bit confusing at first. Thanks for posting here-would love to see more pics!
Kevin - thanks for the heads up on the scissor jacks, I told my husband! Yikes on scraping them off! But I still wonder if anyone knows about that mystical mounting plate that is suppose to be under the trailer? We were out taking some pics of things in Mini we need to replace, and in looking under her, we could see nothing that looks like a plate? Have you any clue?
Squid - can't wait for the inside pics?!!!! We have family/friends in and around Austin. Do you or have you ever been to Hudson's on the Bend. Cheffy Jeff is a friend of ours.
Reason: added more
Leigh, You are NOT looking for something that looks like a plate, nor a flat piece of metal exactly. The mounting plate that many have referred to here is an axle mounting plate. It is about 5 ft. long, 1 flange is about 3 in. and attaches to the frame, the other flange is approx. 8 in. and connects to the axle. Its purpose is to spread the impact of the weight of the trailer over a reinforced area to connect to the axles. When using this mounting flange as a jacking point you are putting the jack under the lowest edge of the flange. Thereby spreading the weight of the trailer to the frame just as if it were supported by the axles. Lifting the trailer off the ground from any other point puts the entire weight of the trailer or a good portion of it on an area of the frame the size of the top of the jack. That is why stabilizer jacks are NOT used to lift the trailer. The balancing stabilizing jacks on our 6.7 meter mount at the frame on one end and a crossmember at the other.
They should not be used for changing tires, long term storage or to take the weight off of the axle. As many have stated this can flex the trailer frame and do permanent damage. Think of this plate as a piece of angle iron.
Larry....Lou typing!
__________________ CP: W/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
AIR#2695
We posted some photos on the axle replacement and there is a photo that may help you see. Larry drew a pencil circle around the piece, but it is very light and you will have to look closely.
AIR#2695
Thanks Loudruff for the input. I do plan to get one of those portable fridges and the 12 v would be useful there. Question: I am pretty uneducated about battery care. If I am hooked up to 110 power while parked, does this keep my battery charged and up to snuff? I understand that a Battery Float Charger would be good (or a Batery Tender) and necessary if stored and not hooked up to regular power. Any educator out there to help would be appreciated. Thanks
__________________ Dan in Mississippi, formerly of Ohio, New Hampshire, Alaska, New York and New Guinea...among others.....
From Paul Theroux: ..the difference between a traveler and a tourist is.."travelers don't know where they're going, and tourists don't know where they've been"
Leigh,
So this is my first offical post. I bought a 77 Minuet off Ebay two months ago and this weekend I'm finally able to go and pick it up. Not my first trailer, but I'm pretty sure this will be the most fun. I'm amazed at all of the good info on this site. I'm sure once I get my "prize" home, I'll be asking all kinds of questions.
I'm writing in blue as I got a note from Campman that the red/orange was hard to read and I want everyone to have the benefit of all the great info being posted.
Lou/Larry, thanks for taking the time to reply & post the pic - I guess somewhere I thought I read there was some kind of actual spot that showed where the axle mounting plate was - something w/a big X on it for aXle mounting plate!!!! Maybe the newer AS's have it. I was trying to find out more cause when we do get our new axle we will probably want to lift "Mini" during the winter to prolong it's life.
Jim - I think its great that you made this your 1st official post and look forward to when you have your new baby home & can let us share all your excitement. There are so many very nice, helpful people who post at airforums. I wanted to have 1 area where the Minuet people would be able to share anything they might come up against that is unique to these trailers. Not that others might not share, but just so we dont have to hunt too hard to find out more about the Minuet. It is a wonderful, fun, sturdy little trailer.
One other question that has come up for us is the placement of a 12v plug receptical in each of your trailers? In the Owners Manual there is a drawing on Pg 90 showing electrical outlets. The solid dot is suppose to be the 12v standard and on the 6.7 drawing it shows 3. 1 is in the bath (we have that) 1 in kitchen area (nope) and 1 up front (nope). Does anyone have more that 1 and are they in the areas pictured? I'm curious as "standard" I thought meant it should be there?
Our Minuet has only ONE 12v. plug installed as original. The one that is located in the bathroom under the mirrored cabinet, streetside. Larry has wired in an extra one by tapping into the fuse panel under the front gaucho. He put a long cord on it. I sleep with a CPAP machine (sleep apnea) and I want to be able to use it while boondocking with battery power. Works great!
AIR#2695
