Greetings Wardster!
Originally Posted by wardster
Does anyone have a rough idea on the cost for a replacement? My original is about shot.
Thanks!
I have had very good luck working with my regular dealer for off-season deals on such things as Air Conditioners. When I had the air conditioner installed in my Minuet (Coleman Mini-Mach), the total installed cost was less than $700 which included cutting the hole in the roof and installing a new circuit breaker for the Air Conditioner. The only down-side to the Mini-Mach is that it does not have provisions for the condesate drain so the condesate drains down the sides -- a greater problem with the Minuet than the Airstream -- I have had no ill-effects from this arrangement with the Airstream, but on the Minuet, have had problem with rust streaks along the sides.
Good luck with your search!
Kevin
