Old 04-12-2007, 10:26 AM   #15
Devils Lake , North Dakota
I am not too concerned about keeping this original as far as the paint goes. I just can't take the brown/copper at all. Probably go with white. How does one tell when you need new axles??? This has not see a ton of travel in its days. Mainly parked at a lake lot with occasional short trips.
Sundance is offline   Reply With Quote
Old 04-12-2007, 10:32 AM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Basically, any Airstream product built before 1975 will need its axles replaqced. You can tell if it needs them now by looking at the angle of the torsion arms, and by bouncing around inside the trailer. If the hub part of the torsion arm is above the cener line of the axle, they need to be replaced, and if when you jump up and down in the trailer it doesn't really bounce, or "give", you need new axles.
For further info on axles, you can go to www.inlandrv.com, and check the axle info provided there.
Also, the absolute worst thing for torsion axles is to sit for 20 years without moving, they will "sieze".
Old 04-12-2007, 10:51 AM   #17
Thanks....... It bounces nicely at this point. I will check the hub in relation to the axle.
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
1985 Argosy MH???? ViewRVs Airstream Motorhome Forums 8 03-21-2002 07:39 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-02-2002 11:21 PM
