Old 11-29-2006, 04:48 PM   #1
Brakes for a 6 Metre Minuet?
Been going through some posts and read where some have brakes on their 6 Metre Minuet. Was this standard issue? Do you suggest this? I'm pretty sure I don't have them on mine.
I'm a week away from submitting her to a shop to have some serious work done!! Just the major stuff. I don't have the time or knowledge to do it myself...
wardster is offline   Reply With Quote
Old 11-29-2006, 05:21 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
All Minuets came with drum brakes mounted on the axle. Yours did too....
At 2400 lbs your trailer is required by law (in almost every state) to have trailerr brakes.
They need to be plugged into your tow vehicle via an umbilical to be operated by a brake controller in your vehicle. The brake controller was and is usually an add on feature - unless your vehicle came with a factory tow package.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 11-29-2006, 08:14 PM   #3
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
When they pack the bearings, have the shop check the magnets in the brakes OR just get new backing plates with shoes and magnets and put them on. They cost about $100 for a pair. Check the wiring for continuity from the connector to the brakes and be sure the break away switch is OK. The brakes are really pretty easy to put back into commission and will make towing MUCH safer.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 11-29-2006, 08:20 PM   #4
Argonaut20's Avatar
1966 17' Caravel
Here's a handy link for brakes and wheels.
http://www.etrailerpart.com/
2006 Toyota Tacoma
Old 12-28-2006, 07:46 AM   #5
I have, what appears to be, a brake contraption on my hitch. I then connect the wire leading from it to my towing vehicle. Looks like if she fell off, it would then engage the brakes. Is this all I need or should I have the trailer brakes hooked up to the towing vehicles brakes so they both work at the same time?
Old 12-28-2006, 07:55 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Warster ~ The connection to the trailer brakes should be through the 7 pin connector on your Tundra. You will need a brake controller installed in your truck as well. I put a prodigy controller in my Tundra. You can get a cable that just plugs into the wirering of the truck. The thing you are seeing on the hitch is most likely the break away switch. It's function is to lock the breaks of the trailer if it detaches from your truck. It should have a pin with a cable. The cable attaches to your truck. When the cable is pulled the pin comes out and the brakes engage.
Richard
Old 12-28-2006, 12:10 PM   #7
Yep, that's what I have. I am going to install a new axle in the next year. I guess I'll mess with my brakes then. I have no idea if they work or not.
Thanks!
Old 12-28-2006, 01:02 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
It is potentially disastrous to tow without brakes -- and against the law as Janet points out. Many brake controllers (and the Prodigy certainly does) have a lever to test brakes (below 25mph) and set the calibration. It's easy to tell because the test lever applies the trailer brakes and not the tow vehicle brakes. You will need both a brake controller and the 7-pin umbilical connected for this; the circuit thru the umbilical is not complete unless you do have a brake controller.
Search the Forums on 'compass' -- I crawled under my Argosy and put a simple magnetic compass inside the wheel near the brake drums and had my wife push on the brake pedal (trailer not moving of course). The compass needle did swing about 10 degrees -- not large but enough to tell the brakes were trying to work -- later proven out by the Prodigy test lever application. You need a functioning battery system on the trailer for the breakaway switch to work -- but please note that your brake solenoids could burn out in under 5 minutes of constant application. So you could pull the breakaway lanyard for a test but put it right back in! This would allow a test without hooking up the umbilical.
5 meter Langford Nahanni
Old 12-28-2006, 04:23 PM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
Just to expand on Bob's post. Do not activate the break away with the umbilical attached. Prodigy warns that this could damage the brake controller.
BTW, the prodigy will display NC if you are not connected to the trailer and you activate the hand lever. I would expect the same results if they were not wired up also.
Richard
Old 12-28-2006, 08:28 PM   #10
Ah yes! Thanks, I forgot about that. It's supposed to fry it completely the first time if I recall. Darn sensitive electronics ... but it works very well!
Argosy Minuet 22' and 24' (1979?) overlander64 All Argosy Trailers 67 10-31-2007 09:17 AM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
