Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 07-19-2016, 05:15 AM   #1
75ArgosyRob's Avatar
1975 Argosy 26
Ripley , West Virginia
Bracket on roof?
Curious if anyone knows what this bracket is for that is directly in front of ac on the roof?
I thought it may be to rest the antenna on (which I removed).
Name:	ImageUploadedByAirstream Forums1468926940.857105.jpg
75ArgosyRob is offline   Reply With Quote
Old 07-19-2016, 05:18 AM   #2
"Cloudsplitter"
Thumbs up Welcome Aboard....
TV antenna support.
Old 07-19-2016, 05:24 AM   #3
1975 Argosy 26
Wonder how hard it would be to remove?
Old 07-19-2016, 05:30 AM   #4
Kevin245's Avatar
I cut mine off flush with the base using a hacksaw. Took less about 5 minutes.
William C. Swinney
Old 07-19-2016, 05:57 AM   #5
1975 Argosy 26
I'll have to see if it is just riveted on the top or ties in under roof skin.
Old 07-22-2016, 01:34 PM   #6
1976 24' Argosy 24
1999 30' Excella 1000
White Haven , Pennsylvania
it's just riveted to the roof. i drilled it out and filled the holes with olympic rivets and vulkem
Gkiesel is offline   Reply With Quote
Anyone use liquid roof for fiberglass roof repair? 442 john Airstream Motorhome Forums 4 01-02-2013 01:23 PM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
