Old 07-18-2006, 06:35 PM   #1
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Unhappy Black water tank repair on Minuet
After putting water into the black water tank to check condition, I look outside and see what could be a lawn sprinkler under the trailer. Sure enough, the valve leaks like a sieve, but worse, the tank is cracked where the pipe for the dump enters the tank. The tank appears to be polyethylene rather than fiberglass. So, two questions:
1. Can the tank be repaired and, if so, how? Some kind of plastic weld? Fiberglass wrap? (Since the crack is in the same place that must clamp to the exit pipe, I wonder about a wrap.) If no repair, where to get a replace for a '79 6 Metre Minuet?
2. Is there a source for aluminum to make large pieces for the belly pan? (PO took off 5 feet of belly pan that I need to replace. Made getting at the valves easy, but made a mess of the belly pan.)
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 07-18-2006, 06:41 PM   #2
Argonaut20's Avatar
1966 17' Caravel
A drawing to clarify where the crack is.
2006 Toyota Tacoma
Old 08-03-2006, 09:55 AM   #3
The Painted Pig
Moonshot's Avatar
1979 Argosy Minuet 7.3 Metre
Hailey , Idaho
Images: 14
Hello Argonaut,
I had to replace the black tank on my Minuet a couple of years ago. Andy at Inland RV has some black tanks, but for mine he had to have one customi$ed. I seem to recall that it cost around $500, including shipping.
Mine started as a small leaky crack, but when I was replacing my tank it just crumbled as I removed it.
Scott
Moonshot is offline   Reply With Quote
Old 08-03-2006, 12:53 PM   #4
Argonaut20's Avatar
1966 17' Caravel
I have found two possible sources for a tank built to specs - both about $425 - $450 including S&H. We are down to the fittings and what I have to do to install.
2006 Toyota Tacoma
Old 08-03-2006, 01:14 PM   #5
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
What are your sources?
I know about:
http://www.all-rite.com/customtanks.html
http://www.accutanks.com/ronco_holding.htm
http://www.incaplastics.com/
http://www.ronco-plastics.com
Incidentally we talked about black tank repair way back in episode 5 on theVAP. But I think you've figured out what you need to do already.
-Tim
theVAP - Airstream Podcast
Old 08-05-2006, 11:58 AM   #6
Argonaut20's Avatar
1966 17' Caravel
I am having All-Rite build the tank to spec. I also got a quote from RV Parts Outlet http://www.rvpartsoutlet.com but went with the All Rite folks because they would place the necessary fittings. I couldn't come up with a stock tank that I felt could be adapted for the configuration in the Minuet.
2006 Toyota Tacoma
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
What Grey Water Tank?? niftypkg Waste Systems, Tanks & Totes 6 09-04-2002 07:12 PM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 09:02 AM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
Black water flush davidz71 Waste Systems, Tanks & Totes 14 04-28-2002 04:15 PM
