Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 08-13-2008, 05:39 PM   #1
1975 Argosy 24
Williamsburg , Virginia
Black water tank Floor?
I have a 1975 Argosy 24 and I am replacing the sub-floor under the shower, it has rotted away due to a small leak at the shower faucet. I have removed the shower pan and noticed that there is no sub-floor under the black water tank, is this condition correct???
Does anyone know a source for clear rock guard for this trailer? I think the gray ones just don't look right (big sunglasses) I know their was clear ones from a former trailer that I had 1970 A/S.
paul903 is offline   Reply With Quote
Old 08-13-2008, 05:46 PM   #2
Retired.
. , At Large
You can get clear plexiglass to fit in place of the smoke color. It does cut down on heat, light, and glare inside with the smoke color sunglasses.
You should have a floor under part of the black tank. The part under the toilet should have a floor, and there is a portion of the black tank that extends slightly below floor level for the dump valve to attach to. The part without the floor should be more on the street side of the tank.
Old 08-13-2008, 06:10 PM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Check this out, may help?
Bathroom Removal
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
bathroom floor, black tank, rockguard
Black Water Tank robertpeters Waste Systems, Tanks & Totes 13 06-13-2007 06:26 PM
need new black water tank KHarris Waste Systems, Tanks & Totes 4 09-24-2006 08:34 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Black Water Tank David Hall Waste Systems, Tanks & Totes 3 12-28-2003 07:24 PM
