Old 10-03-2007, 12:17 PM   #1
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
Black tank fun and games...
I have a project for this weekend, removing the toilet and black tank in our '72 20' Argosy. The tank to valve interface has a nasty leak (I think it may be a cracked piece of PVC pipe) that I can't get at from the bottom, so it's time to pull the tank. Looking at the bathroom, it appears that I have to remove the sink, then the vanity, unbolt the toilet and remove the raised floor before I can get the tank out. Does this sound right? The kick panel in front of the tank has seen better days, so I'll be making a new one when everything goes back together.
While I'm at it... My sink is fugly, very discolored and nasty looking - even when cleaned. I was thinking about lightly sanding it down and painting it with an epoxy based paint. As an alternative, I have also thought about taking it to a place that repairs fiberglass boats and have a white gel-coat finish applied. Needless to say, if this works, the shower pan and wall mounted shower console will get the same treatment.
Any thoughts or comments?
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 10-03-2007, 12:21 PM   #2
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Black Tank
You are right on about the removal. You will find that the toilet sits on the black tank with a piece of 1/8" plywood between. I built a platform around the tank with 3/4 X 3/4 oak and topped it with 1/4" alum., which made the toilet stable.
Don
Gunnyusmc is offline   Reply With Quote
Old 10-03-2007, 12:30 PM   #3
bobfowler's Avatar
1972 Argosy 20
Images: 14
Don
Thanks Don, I was afraid I was right... At least the tank is clean!
Bob Fowler
TAC - NJ-007
Old 10-04-2007, 08:50 AM   #4
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
That' it!
Take the time to drill out the rivets, and it really will go by fast. I say about 2 hrs and it will be apart. This is a good time to check out the plumbing in the rear for cracks. It seems like they get freeze damage where they go behind the shower.... PEX is an easy repair product for those pipes.
I say get that top cleaned and sprayed (I remember someone used a POR 15 product with excellent results here).
Good luck!
Marc
Old 10-04-2007, 08:51 AM   #5
1975 Argosy 26
1963 24' Tradewind
Oh yeah. Get a new seal for the bottom of your toilet - or just get a new throne while you're at it.
Marc
Old 10-04-2007, 09:24 AM   #6
bobfowler's Avatar
1972 Argosy 20
Images: 14
Marc
Funny you should mention that... I think that with all the travel we plan with this trailer, we deserve a new john.
Like the King said to the Prince, "Never give up a chance to sit on the throne"
Bob Fowler
TAC - NJ-007
Let the games begin!!! HankandLois Member Introductions 9 08-13-2007 10:08 PM
Black Tank Devoman Waste Systems, Tanks & Totes 14 08-02-2006 12:13 PM
Black tank Gunnyusmc All Argosy Trailers 4 07-19-2004 04:42 PM
Alternator fun and games ALANSD Mechanics Corner - Engines, Transmission & More... 18 10-26-2003 01:04 PM
Black Tank Gunnyusmc Waste Systems, Tanks & Totes 3 07-02-2003 07:38 AM
