Old 01-20-2018, 09:21 AM   #1
1978 31' Excella 500
1973 Argosy 26
Reidsville , North Carolina
Battery Not Charging
My '73 26' Argosy battery doesn't seem to be charging. It's been plugged in for weeks but the battery has gone out from running the lights and heater fan occasionally. Is the battery suppose to charge when it's plugged in? If so, can someone recommend some steps to take to see if it's charging and how to repair it?
bombard16 is offline   Reply With Quote
Old 01-21-2018, 12:30 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you have the original Univolt converter it may have failed. Even if it didn't, it's time to upgrade.
Is there water in the battery?
Have you checked the fuses?
What is the voltage at the battery when you are plugged in?
Is there 120 volt AC power to the converter?
Have you checked the connections at the battery?
Old 01-21-2018, 03:41 PM   #3
1973 Argosy 26
It is the original univolt. Whats the recommended upgrade?
I have a good battery. I haven't pulled the univolt yet to see if everything is hooked up properly, there is a water line blocking me from removing it. It's just not a project I have had as a priority to tackle yet... I guess it's time now.
Old 01-21-2018, 05:41 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I installed a Progressive Dynamics 9245 in my '74 Argosy 26' in 2010. It has worked flawlessly since.
Even without a battery it powers everything.
I usually remove the battery when the coach is stored. Use it for other things. Just tape off the positive lead and plug the coach in. That way I have lights and heat if I need it.
I did install a new fuse block as well.
Old 02-20-2018, 08:49 PM   #5
1973 Argosy 26
Battery Charger
Curious, would a battery charger or trickle charger work temporarily? I can't drop the funds for a new Progressive Dynamics yet.
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 29 09-08-2018 09:12 PM
Shore power not charging battery after battery replacement P and Y Batteries, Univolts, Converters & Inverters 15 11-22-2016 09:36 AM
Battery converter not charging battery airstreamz Electrical - Systems, Generators, Batteries & Solar 5 09-24-2014 04:55 PM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 10:15 PM
OOPS! battery not charging,water hook up spilling into reserve tank? outerbanksdeb Batteries, Univolts, Converters & Inverters 2 08-02-2004 01:40 PM
