Old 04-21-2013, 04:28 PM   #1
WI-78ArgMin6.7
ArgosyMinuet's Avatar
1978 Argosy Minuet 6.7 Metre
Franklin , Wisconsin
Back turn signal light bulb broke and can not get out
See picture. Light bulb was burned out. Broke off glass bulb and copper is ripping apart and still stuck. Any advice. Thanks in advance!
ArgosyMinuet is offline   Reply With Quote
Old 04-21-2013, 05:02 PM   #2
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I've had this happen many times in cars over the years. I disconnect the battery. Spray it pretty heavily with WD-40. Let that soak for a little bit. Then work it out with long-nosed pliers.
Thalweg is offline   Reply With Quote
Old 04-21-2013, 05:10 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Yep...Then coat socket and bulb base with dielectric grease.
Do all bulbs and exterior screws, fasteners, rubber seals and stuff that ain't supposed to stick.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 04-21-2013, 08:24 PM   #4
richinny's Avatar
2011 34' Classic
use the needle nose pliers to collapse the bulb base into itself.
always use a rag over the glass to keep from getting your hands cut if the glass breaks. if the bulb is white it means moisture has gotten on the bulb and it may be cracked.
Ricky
Old 04-21-2013, 10:38 PM   #5
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Always a good idea to wear gloves when installing bulbs too...because the oils from your fingers can shorten the bulb life by creating a hot spot. Dilithium (mentioned before) will also extend bulb life by nearly 2 x.
Phrunes is offline   Reply With Quote
Old 04-22-2013, 04:36 AM   #6
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Just make sure the dilithium is properly aligned to channel the antimatter, if not, a broken bulb will be the least of your problems...
