Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 06-09-2009, 02:54 PM   #1
1977 Argosy Minuet 6.0 Metre
SPOTSYLVANIA , Virginia
axle problems
Everyone is concerned about replacing axles-can someone explain-are they breaking, bending,? how do I know I need to replace my minuet axle?
vcu70 is offline   Reply With Quote
Old 06-09-2009, 02:58 PM   #2
SteveH's Avatar
Common Sense , Texas
I'm not replacing mine, but the problem with the axles on the older trailers is the rubber inside the axle gets hard and "dead" with age and no longer has any spring to it.
The way to determine if yours are bad is to look at the swing arms from under the trailer and see if they are still angled down. If they are bad the swing arms will either be straight with the frame or even angled up.
You can also jack up the trailer and if the axles are good, the wheels and swing arms will have some downward travel.
Old 06-09-2009, 03:37 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
axle problems
Greetings vcu70!
There is an excellent article on Vintage Airstream.com that explains how the Dura-Torque works and how to assess its condition.
Another reason to replace the axle on a Minuet 6.0 Metre is that the base axle is easily overloaded if the coach is not packed carefully. I went with the next heavier axle having a rating 500 pounds greater than the original.
Good luck with your axle assessment!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 06-09-2009, 06:20 PM   #4
adore's Avatar
Mont-Laurier , Québec
What is the rating of your new axle for your Minuet?
Originally Posted by overlander64 View Post
Greetings vcu70!
Kevin
Hi Kevin:
What is the rating of the axle you selected?
André
adore is offline   Reply With Quote
Old 06-09-2009, 07:36 PM   #5
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 194
axle problems
Greetings Andre!
Originally Posted by adore View Post
Hi Kevin:
André
The 1978 Minuet 6.0 Metre had a 3,000 pound axle as standard. The new axle was ordered with a rating of 3,500 pounds. I just wish that I could have convinced the shop doing the work to go with the maximum down angle as I only gained 1.5" of additional clearance with the new axle.
Kevin
Kevin D. Allen
AIR #827
Dura axle problems , on the road ? brunoffrance On The Road... 3 04-19-2009 11:16 AM
Axle Ring Problems noiva Axles 13 09-21-2006 02:14 PM
New axle problems and questions 63air Axles 8 10-04-2005 07:41 PM
Aging Airstreams and axle problems glacierrunne Axles 6 04-11-2005 10:39 AM
