Old 12-01-2014, 09:32 AM   #1
1977 Argosy 24
Milltown , Wisconsin
AS tail lights on an Argosy
I was thinking about putting Airstream tail lights on my 77 Argosy 24. I was wondering if it can be done entirely from the outside, or do you also have to remove the inner panels in the bathroom to install them? What year AS tail lights would be the best fit?
ventport is offline   Reply With Quote
Old 12-01-2014, 10:32 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I'm looking at this for my '76 because the Argosy plastic taillight housing is trashed, and I happen to have a pair of Airstream taillight modules that someone has installed in the parts trailer I bought.
It looks to me like you'll have to cut some aluminum to make them work (with the pair of '70s taillights I have, at least) because the Argosy just has a hole cut to pass the wires through, and the Airstream '70s Airstream taillight modules aren't surface-mounted.
David
Old 12-01-2014, 06:28 PM   #3
1977 Argosy 24
Could you post a picture of the backside of one of the taillights showing how they are mounted?
Old 12-01-2014, 10:54 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
They're still stuck to the back of my parts-donor Argosy, which is at the shop that'll do the big work to make my '76 a good platform for renovation. Hopefully someone else has a photo of '70s Airstream taillights removed from the trailer.
David
Old 12-02-2014, 06:53 PM   #5
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
It seems like I read a post in the argosy section and they used mid 80's Excella lights. Then another post used Bargeman lights
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 12-03-2014, 06:44 AM   #6
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
When I removed the plastic valance that holds the tail lights on my 73, I had to also remove the center trim rail. The rivets holding the plastic were under the rail. There were rather large rectangular holes in the aluminum suggesting that the rear panels were multi use and that A/S lights might fit.
Gearheart is offline   Reply With Quote
Old 12-03-2014, 03:26 PM   #7
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
There are several options for this as I recall. I bought some used AS lights that the seller told me were the correct radius for the curve on the Argosy and I had no reason to doubt him, he was a former AS repair center owner. But when I tried to fit them, the radius was wrong and there was quite a gap. These were not flush mount as I have seen elsewhere.
I have posted the two pics that another member posted of the mod they made to their trailer and a pic of the two light clusters I bought which will not fit.
Name:	Rear light clusters.jpg
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 12-03-2014, 04:45 PM   #8
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
I installed some late model cast aluminum led Airstream lamps on a 77 Argosy some years ago. Although the arc wasn't exactly the same, the skin flexed enough, so there were no gaps. They looked really cool.
Vintage Thunder (Airstream Life's project trailer) was a 77 Argosy & it had 80's era Airstream taillamps on it. They fit well also.
Colin
Colin H is offline   Reply With Quote
Old 12-04-2014, 08:38 AM   #9
1977 Argosy 24
Thanks everyone for all the good info. What year AS are the lights in the last picture that BEX posted from? They seem to fit perfectly. Do they mount entirely from the outside, or do you have to remove panels from the inside to mount them?
Old 12-04-2014, 09:12 AM   #10
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Those are the same ones that went on Vintage Thunder. I'm guessing 80's era.
Colin
Old 12-05-2014, 08:06 AM   #11
Bex
1976 Argosy 28
You would need to spend a little time searching the threads for the original poster. I thought (as Colin suggests) they were from an early eighties.
Anyone know of LEDs for the rear marker lights on mid '70s on the tail lights? Mixter Lights - Interior & Exterior 8 11-11-2014 08:27 PM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
1972 Argosy tail lights - free to good home bobfowler All Argosy Trailers 8 05-06-2008 06:24 PM
