Old 05-01-2005, 08:25 PM   #1
CanoeStream's Avatar
St. Cloud , Minnesota
Thumbs down Argosy water tank contamination
1970's Argosy trailers with a front gaucho commonly have the water tank above the floor and under the gaucho at the very front of the trailer. If you have a water filler door like this one under your front window, I've got to add one more gasket for us all to check.
I have replaced the front 4' of my floor due to rot from a leaking wraparound window frame. I've Rot-Doctored and epoxy coated the most hidden areas of the new floor under the tank. I'm very close to reinstalling the water tank, pump and gaucho. While leak testing the exterior yesterday I experienced a flood from leakage around the water filler door. The gray plastic molding inside the filler door acts like a funnel, channeling the water to a pipe-clamped hose attached to a filler tube on top of the tank.
It turns out there is a hardened foam gasket on the perimeter of the water filler door that has long since lost its seal (photo below). This is the ONLY barrier to rain water and road spray entering the fresh water tank! I don't know the material or thickness before it was squished to less than 1/8". Guess I'll be looking around for a closed-cell substitute. A number of better fixes come to mind.
If you think gasoline can get old, you wouldn't believe the algae gobs and green water I flushed out before I considered basic tank cleanup complete. I'll pay for gallons of spring water around the country before I feel comfortable drinking out of my fresh water system. Nothing beats constant use and regular flushing to maintain a clean system. Various threads have been around on periodic maintenance -- do searches on 'potable water' or 'bleach' ... and on and on.
Anybody else dealt with a similar door on their Airstream or Argosy?
Name:	Water Filler Cover.jpg
5 meter Langford Nahanni
Old 05-01-2005, 10:08 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
YUCK! we have the same set-up. My adorable husband hyper chlorinates the entire system each year and is fastidious about draining after each trip. To date we haven't had globs.... but we did have to repair the filler "tube" and I agree that there is little to prevent road crud and other mystery substances from entering the fresh water tank. You can replace the door and filler with new stuff.....
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 05-01-2005, 11:33 PM   #3
Airstream has a step-by-step method for cleaning your freshwater holding tank.
You can find it under their customer service link from the main page. It has worked for my family for over thirty years.
Anon is offline   Reply With Quote
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
