Old 04-24-2008, 07:14 PM   #1
MuthaMustard's Avatar
los Angeles , California
Send a message via AIM to MuthaMustard Send a message via Yahoo to MuthaMustard Send a message via Skype™ to MuthaMustard
Argosy Specs?
Hey guys,
We are compairing the Airstreams to the Argosy and I have heard that the Argosy is lighter but can not find the weight specs like I could the A/S specs. Anyone know??
We need a lighter trailer because of our TV specs
Please INFORM ME..........
Thanks Mucho,
Orite
MuthaMustard is offline   Reply With Quote
Old 04-24-2008, 07:56 PM   #2
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
I don't have the official specs for Argosys; however, I have a 1978 24ft Argosy that I took to the truck scales before I towed it home from El Paso. It had no water in it, or actually anything else extra at the time. The weight was 3608 lbs. Of course by now I'm sure it exceeds that weight by about 500 lbs. You sure can get a lot of "stuff" into one of these in a very short time. I have the double bed in the middle and there is a lot of storage in the trailer. The mid-twins don't have as much.
Judy At Home in Oklahoma
juel is offline   Reply With Quote
Old 04-24-2008, 08:28 PM   #3
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Square Argosy
The weights for the 1986-1989 square Argosy can be found at
Airstream trailer forums.Click squarestream,click updated squarestream history.Click on page to make larger to read.Has most weight info.
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 04-24-2008, 09:52 PM   #4
I checked those, but I am looking at the 70's models. Smaller for my Tow Vehicle.24 ft tops seems to be my cut off. I will keep searching but if anyone knows, please chime in......chime chime chime
Old 04-24-2008, 11:13 PM   #5
strmstr69's Avatar
Auburn , Washington
Here are some weights as shows in my owners manual:
20 ft.............4450 gvwr...........2880 fac dry wt..........470 tongue wt
22 ft f/d.........5800 .................3360.........................560
22 ft r/d.........5800 .................3720.........................410
24 ft T .........5800 .................3610.........................560
D ........5800 .................3620.........................560
26 ft T..........6200 .................3830.........................520
D .........6200 .................3850..........................520
28 ft r/b /T.....6200 .................4020..........................510
D.....6200 ..................4040..........................51 0
28 ft c/b /T....6200 ..................4375..........................40 5
D....6200 ..................4370..........................40 5
f/d = forward door
r/d = rear door
r/b = rear bath
c/b = center bath
T = twin.
D = double
Hope this helps.....Dan
strmstr69 is offline   Reply With Quote
Old 04-24-2008, 11:34 PM   #6
Wahoo, here are a couple of great finds I came up with tonight. Thought I would share them. pretty neat stuff.
http://www.airstreammotorhomes.com/t...gosy_22_24.jpg
http://www.airstreammotorhomes.com/t...gosy_20_22.jpg
Fred's Airstream Archives - Trailer Floorplans
Hmm I think I am in love.
Thanks for the owners manual specs. Now how to figure out how this all works with so many tow weights. It seems a bit confusing. I guess things are always that way at first.
Old 04-26-2008, 05:53 PM   #7
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
I'm with you ... it is still a bit confusing for me. I've had my 72 Argosy 22 for just under a year and when I look at those weight charts I get more confused. I forget what the nameplate says, but the previous owner had it weighed and it was nearly 4800lbs almost empty. I would keep that in mind when considering a tow vehicle. Just my "rookie" 2 cents.
biggoofball is offline   Reply With Quote
Old 04-26-2008, 08:50 PM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The "factory dry weight" is the base weight of the trailer, not including options or accessories. An air conditioner or awning would not be included in the dry weight figure, nor would fresh water or LP.
Old 04-26-2008, 08:57 PM   #9
geirws's Avatar
1977 24ft. argosy MH with a 454 engine is 13,500 lbs
geirws is offline   Reply With Quote
Old 07-07-2012, 08:47 AM   #10
1972 Argosy 24
Amsterdam , N-H
I'd like to add that our 1972 Argosy 24T2 has a GVRW of 3,800. That must mean that the empty trailer weighs substantially less, presumably around 3,000. I am sourcing an original owner's manual and will post any updates.
Tocht is offline   Reply With Quote
Old 07-07-2012, 08:54 AM   #11
saburkha's Avatar
1976 Argosy 28
Tuscola , Texas
What tow vehicle are you planning on using?
saburkha is offline   Reply With Quote
Old 07-07-2012, 12:03 PM   #12
Norman , Oklahoma
It probably varies some by year, but here is a link to Airstream's Argosy specs (for 1973 I think):
http://www.airstream.com/files/libra...e7c0f6c7fc.pdf
ready2move is offline   Reply With Quote
Old 07-07-2012, 01:12 PM   #13
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Argosy Specs???
Greetings Tocht!
Welcome to the Forums and the world of Vintage Argosy Travel Trailers!
Factory data about the first generation was comparatively scarce until the past few years. Airstream has added more information about the first generation Argosy travel trailers to their site with almost every refision . . . but they also juggle the data so that links often don't work to materials after a revision.
Today, the site doesn't have much information for the 1972 coaches, but they do have the page from the showroom literature that gives the standard equipment for the 1973 coaches which wouldn't have been significantly different from the 1972 coaches. You can find this document at this link. They also have the suggested retail prices for 1973 Argosy coach's at this link. Argosy trailer weights are also posted at this link for 1973. I realize that this information is for 1973, but any information for the 1972 model year, the introductory year for the first generation Argosy travely trailers is quite limited. I am including a scan of my brochure for 1975 Argosy travel trailers, the floorplans illustrated will be quite similar to your 1972, but there will likely be some changes.
Good luck in your quest for information about your coach!
Kevin
Kevin D. Allen
AIR #827
Old 07-09-2012, 07:54 PM   #14
1972 Argosy 24
Amsterdam , N-H
I plan to use my 94 Buick Roadmaster, plus tow package. Just upgrading from Class 2 to Class 3 hitch to have some reserve capacity.
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 07:46 PM
1972 Argosy Exterior Refinish billymyers56 All Argosy Trailers 47 02-04-2013 09:18 PM
Question regarding sleeping & eating in a 1978 28' Argosy.. Rick F Argosy Motorhomes 4 09-01-2011 11:40 PM
Argosy :: 1974 Argosy dlb56hdt Airstream Registry Discussions 0 08-19-2011 08:32 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
