Old 07-09-2012, 07:56 PM   #15
1972 Argosy 24
Amsterdam , N-H
Originally Posted by Tocht View Post
I'd like to add that our 1972 Argosy 24T2 has a GVRW of 3,800. That must mean that the empty trailer weighs substantially less, presumably around 3,000. I am sourcing an original owner's manual and will post any updates.
I plan to use my 94 Buick Roadmaster, plus tow package. Just upgrading from Class 2 to Class 3 hitch to have some reserve capacity.
Tocht is offline   Reply With Quote
Old 07-09-2012, 07:59 PM   #16
1972 Argosy 24
Amsterdam , N-H
Thanks, I'll check this out.
To my surprise, at Camper Barn in Kingston I saw a 28 1975 Argosy that supposedly had a GVWR of 3,200 on the VIN plate... Can't be right.
Old 07-09-2012, 08:17 PM   #17
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Tocht
I would say that the dry weight of your trailer would be 3,800 lbs, possibly including options. The empty weight might be 3,610 lbs. I would guess that the Gross Trailer weight would be around 5,600 lbs.
Dan
Old 07-18-2012, 12:01 AM   #18
1972 Argosy 24
Amsterdam , N-H
Gvwr
Originally Posted by TouringDan View Post
Tocht
Dan
Tx Dan,
I am upgrading to a class III hitch anyway. But what does GVWR on the VIN plate mean then? I always thought this was the max allowable weight.
Old 07-18-2012, 06:23 AM   #19
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
That's what it means. The empty weight on my '74 Argosy 26' is 3900#. The GVWR is 6200#. The empty tongue weight is 540#. The loaded tongue weight is 820#.
The class 3 hitch would not be rated for this tongue weight without WD. There are a lot of ball mounts out there that are not rated for the load you are carrying. Be sure to check the specs of the ball mount.
I recently upgraded from a class 3 to a class 5 hitch.
Old 07-19-2012, 09:16 PM   #20
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Tocht
You are correct. That is what it means. However if your Vin plate lists the GVWR of 3,800 lbs, I would say that it is an error.
Dan
Old 08-21-2012, 08:49 PM   #21
Germantown , New York
Argosy 24" GVWR
Tocht
Dan
You are totally right Dan, this was an error, not an Airstream error but my own. The VIN plate is hardly readable but after a lot of opinions heard we believe it says 5,600 lbs as GVWR and 2,800 for each axle. That make sense?
Our tow horse is a 1994 Buick Roadmaster and we upgraded our hitch to a 2"x2" U-Haul hitch rated 1,000/10,000 lbs with weight distribution (thank you Indy at BadAss). With weight distribution made in China and a sway control made in Taiwan, both sold by Campers Barn in Kingston, NY (now Campers World, thanks Don and Jerry, hang on), the trailer behaves beautifully and the tow is uncomplicated.
We are currently traveling through New England, having great fun - now at the most Eastern campsite in the USA - Lubec, Me.
Jwcberk is offline   Reply With Quote
Old 08-22-2012, 08:40 AM   #22
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
I am glad that you got your specs figured out and upgraded your hitch.
Nice that you are out having fun camping, and that you are camping in the most eastern spot in the US.
Please post a photo, so we all can see where you are at and see your Argosy and Buick Roadmaster. My grandpa always had a Buick for a TV when he would tow his trailer to Florida in the winter, from Michigan, in the early 50's.
Dan
Old 09-01-2012, 08:14 PM   #23
1972 Argosy 24
Amsterdam , N-H
Argosy 24 & Buick Roadmaster
Attached a not so great picture of our train. Better pictures to follow after downloading the camera. We just finished an almost 2,000 mile three weeks trip through New England. Argosy behaved beautifully except for a broken water pump and a few 40 year old rivets getting loose. The original bathroom mirror all but crashed. Saved it in time. Need to find out how to do the riveting myself.
The '94 Roadmaster had no issues towing the Argosy, power is more than adequate. I would consider a stiffer springs set up in the back and stiffer shocks in front in time.
The lines of the Argosy and the Roadmaster match well and make people believe that the Roadmaster is a lot older than it actually is. The combi drew lots of thumbs up and cheers along the way, most notably from a crowd at Hippie Hill in Danbury, NH.
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 07:46 PM
1972 Argosy Exterior Refinish billymyers56 All Argosy Trailers 47 02-04-2013 09:18 PM
Question regarding sleeping & eating in a 1978 28' Argosy.. Rick F Argosy Motorhomes 4 09-01-2011 11:40 PM
Argosy :: 1974 Argosy dlb56hdt Airstream Registry Discussions 0 08-19-2011 08:32 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
