Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 12-02-2005, 10:05 AM   #1
misterbee's Avatar
Profile:
Argosy screens
Hiya,
I just took possesion of a 20 foot '78 Argosy. It has been greatly modified from original, and has no screens on any of the windows. The window frames do appear to be original, but it's not apparent to me how screens fit on the windows. All I have been able to imagine is that I can unscrew the inner frame, lay out some screen fabric, and replace the frame. does that make sense to anyone, or can anyone point me in the right direction?
Thanks for your time.
misterbee is offline   Reply With Quote
Old 12-02-2005, 11:45 AM   #2
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
That's it...
From the inside, you should see a screw in frame. This is what the screen fits into (with a new rubber spline). I can't remember off the top of my head (trailer is elsewhere) if the spline faces towards the inside of the trailer or outside.
Any screen material will do.
Marc
3Ms75Argosy is online now   Reply With Quote
Old 12-02-2005, 12:37 PM   #3
misterbee's Avatar
Profile:
Thank you!!! Anyone know where I can get the rubber spline?
Old 12-02-2005, 12:43 PM   #4
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
Home Depot, Lowes, Ace Hardway to name a few. Make sure you measure the width of the opening, it comes in more then one size. Also, buy a spline tool. They only cost a couple of bucks, but are well worth it.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 12-02-2005, 03:13 PM   #5
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Hiya,
misterbee,
You may want to put the screening in with the frames attached to the trailer...they are curved not flat like a house screen. My first attempt to replace my screen with the frame off the trailer was not a pretty sight. It came out better for me to leave the frame attached...
Aaron
WBCCI #2449 AIR #2495
Old 12-02-2005, 05:19 PM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
My Argo is shivering in the driveway right now. I'll head out there in the morning and take some photos if others don't turn up by then...
Old 12-04-2005, 12:58 PM   #7
Images: 13
Howdy again misterbee -- It seems the screen material is the only missing part. Right? The detail picture below is the square-cornered front window; this should make insertion of the rubber spline quite apparent. The other is one of the rounded side windows. (Click within the picture to get an enlargement.) Does this do it for you? Other pics or further description is possible ... let me know.
I think you'd want to install this without removing the frame.
Name:	Screen detail 3.jpg
ID:	16872   Click image for larger version
Name:	Screen detail 4.jpg
Old 12-10-2005, 11:12 AM   #8
misterbee's Avatar
Profile:
Thanks!
Thanks for the images, that really clears things up for me....
Old 03-13-2006, 10:54 PM   #9
Geezer
Profile:  1976 Argosy 24
Sapulpa , Oklahoma
Thanks Aaron. I am am just getting ready to do my screens. I am going to use insect screen with super small holes. Were you able to use the old inserts?
LRPorter is offline   Reply With Quote
Old 03-14-2006, 12:59 AM   #10
Van
Profile:  1977 23' Safari
Hillsboro , Oregon
Welcome to the forums and greetings to another Argosy owner. I replaced all the screens in my Minuet after i took possession of it. Its a rather easy job, just time consuming.
Van
2005 F-150 FX4, SC, 4X4, 5.4 V8
former '78 Argosy 20' Minuet owner
former '77 23' Safari owner
current 25' Fun Finder X-250BHS SOB owner
Van is offline   Reply With Quote
Old 03-14-2006, 04:19 AM   #11
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Most of my spline was reusable. If yours isn't take a scrap to the store when you go to match it up. Biggest problem with the old stuff is that it will stretch and be brittle or rotten. The stuff is realtively cheap.
Aaron
Old 07-01-2006, 04:53 AM   #12
Profile:  1977 29' Ambassador
Great Meadows , New Jersey
Hi, I'm refurbshing a '77 Ambassador. It has white fiberglass (I think) bug screens and I need to replace the mesh. It seems I can have any color I want as long as it is black or charcoal! Does anyone know where I could get a white insect mesh?
Phil.W
'77 29' Ambassador. '89 F250 Diesel 4x4.
philw is offline   Reply With Quote
Old 08-03-2006, 02:22 PM   #13
SmokelessJoe's Avatar
TORONTO and Southwestern , Ontario
People:
Anyone else that has done this and can help?
Was the bug screen in the 1976 Argosy made of metal or fiberglass? It appears to be an aluminum-like colour.
Are the Big Box Store replacements commonly fiberglass these days?
Anyone know the size of the spline tool required?
I’ve always had trouble replacing window screens. Maybe the mostly rounded corners here will make it easier?
WHAT ABOUT THAT CLOTH MATERIAL AROUND THE LEVERS THAT KEEPS THE BUGS OIUT?
Where can we get that? Airstream have it?
Allied question: what about the rubber gasket around the window glass - is this a commonly available molding or do we have to get it from Airstream?
Thanks for your help.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 08-03-2006, 04:29 PM   #14
Old Paint, rolling again.
sfixx's Avatar
Profile:  1973 Argosy 20
Lorain County , Ohio
Images: 13
Send a message via AIM to sfixx
Bugged
I delayed replacing the window slider fuzzies and boy was that stupid. Last weekend the bugs found the way in (after dark) and I ended up stuffing tissues in the cracks.
You can buy the stuff by the foot from Inland RV. But Airstream probably sells it too. Andy at Inland sells the window gasket material too.
BTW, I replaced my screens too. Very satisfying job
You want the smaller spline and the 2 ended tool usually fits both sizes.
Best of luck!
Steve
Have you never questioned those who travel?
Have you paid no regard to their accounts- Job 21:29
Fixxer's Argosy Resto-Blog
Courtesy Parking: 15 minutes off the Ohio Turnpike West of Cleveland... W/30 amp/water+WIFI ...The Next Best Thing to Larry and Lou's TM
sfixx is offline   Reply With Quote
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 7 06-20-2007 12:18 AM
Argosy Motorhome Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 09-26-2006 06:21 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 10:36 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 08:14 PM
1985 Argosy MH???? 1985air345 Airstream Motorhome Forums 8 03-21-2002 08:39 PM
