Old 04-16-2016, 09:04 PM   #101
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Name:	ImageUploadedByAirstream Forums1460862025.612818.jpg
ID:	260883Click image for larger version
Name:	ImageUploadedByAirstream Forums1460862060.492290.jpg
Installed the new door lock set today! The old one was leaking like crazy. The piece of wood had dead termites in it! No more leaks now and it came out great👍😄
Matt
rugjenkins is offline   Reply With Quote
Old 06-09-2016, 10:12 PM   #102
rugjenkins's Avatar
1975 Argosy 28
I never really like the old molded abs tail light housing on my argosy! So installed these. They give a cleaner look and they are led.Click image for larger version
Name:	ImageUploadedByAirstream Forums1465531825.133112.jpg
ID:	264135Click image for larger version
Name:	ImageUploadedByAirstream Forums1465531838.568431.jpg
ID:	264136Click image for larger version
Name:	ImageUploadedByAirstream Forums1465531855.868948.jpg
I had to cut big holes . This is an easy mod but not for the squeamish😄
Matt
Old 10-20-2016, 01:37 PM   #103
Houston , Texas
Matt, this is a dumb question, is your subfloor slightly smaller to fit inside the steel tubing that you welded to the outriggers? If that is the case, does any of the C-channel from the shell get bolted to the subfloor or does is sit squarely on the tubing?
Gary
Disable is offline   Reply With Quote
Old 10-24-2016, 09:04 AM   #104
rugjenkins's Avatar
1975 Argosy 28
No dumb questions here👍 the c-channel is completely removed. The shell (the ribs) are bolted to steel stubs welded on the frame. The subfloor sits inside the steel tubing frame. I raised my shell about 3 inches higher than original. The new belly pan is the riveted to shell to give it a clean look. I didn't like the original setup of the shell on subfloor with the belly pan overlapping the shell. (I felt it was improper engineering- it was made to fail) so I took the time to underlap the belly pan so that the water would shed off as it does on a house. Plus the floor can be removed now without taking the shell off. I like it. It's a better common sense design. Click image for larger version
Name:	ImageUploadedByAirstream Forums1477321185.141868.jpg
Here you can see the new floor, steel stubs/rib connection, steel tubing frame and new belly pan attached to the shell.Click image for larger version
Name:	ImageUploadedByAirstream Forums1477321406.610413.jpg
Here is a pic of the outside with it all back together belly pan and all
Matt
Old 11-27-2016, 06:18 AM   #105
GoNomad's Avatar
1975 Argosy 28
Anderson , South Carolina
Thanks and a question
Matt, Great thread we are just in the planning stage and have found your thread very helpful. How did the ceramic addition to the paint go? Did you roll or spray? have you noticed any changes in temp? Are you DIY the spray in insulation or having it done?
Thanks again looking forward to following your progress.
Nick & Holly
1975 Argosy 28 Rear Bath 1963 Shasta Airflyte
2008 Toyota Tundra Double Cab SR5 5.3L 4x4
"We've got PBS minds in a MTV world" J.B.
GoNomad is offline   Reply With Quote
Old 11-27-2016, 07:16 PM   #106
rugjenkins's Avatar
1975 Argosy 28
The ceramic was rolled on. There is a noticeable difference on surfaces with the ceramic paint. It's one of the cheaper upgrades. The whole camper is DIY.👍😄 I used 2 methods for the insulation: 2 part spray foam and great stuff with a triangle nozzle. 1/3 was done with the 2 part spray foam. The other 2/3 with the great stuff from a can. I prefer the great stuff from the can. It was more uniform with no hazards to my health! Plus it was 1/2 the cost!
Matt
Old 12-26-2016, 07:41 AM   #107
GoNomad's Avatar
1975 Argosy 28
How is it going?
Just wanted to check in and see how your project is going? We just got started with the gutting of the bathroom to do floor repair and plumbing/electrical upgrades.
Also could you add your information and Vin Number to the Argosy database? it can be found here http://www.airforums.com/forums/f227...se-106682.html
Hope all is well
Nick & Holly
Old 03-30-2017, 03:05 PM   #108
rugjenkins's Avatar
1975 Argosy 28
All is well, home projects take priority so work on the camper stopped. Electrical, plumbing and insulation are done![emoji106] ready to place interior panels. Not sure if I will reuse the interior end caps. Possibly of either wood or aluminum 13 panel. Why do easy, right?[emoji12]
Matt
Old 03-30-2017, 03:09 PM   #109
rugjenkins's Avatar
1975 Argosy 28
I'll post pics of the finished insulation and my "save a ton of money method" for spray foam insulation [emoji1]
Matt
Old 01-23-2018, 02:55 PM   #110
rugjenkins's Avatar
1975 Argosy 28
Pics of spray foamed insulation. I used 2 methods- 2 part component and great stuff with a special nozzle. Click image for larger version
ID:	302874Click image for larger version
Matt
Old 02-19-2018, 10:26 AM   #111
rugjenkins's Avatar
1975 Argosy 28
Finally finished shaving the foam! In hindsight I would spray first then cut channels to run the electrical. I plan on spraying the foam with a semi gloss latex in white to help further seal the foam that was cut. It's overkill. I may even add the rest of the hytech ceramic beads.
Matt
Old 02-19-2018, 10:28 AM   #112
rugjenkins's Avatar
1975 Argosy 28
I have now repaired any wires I accidentally nicked sawing the foam. Cut, respliced with connectors plus heat shrink over that.
Matt
Old 02-19-2018, 10:34 AM   #113
rugjenkins's Avatar
1975 Argosy 28
Here the revised floor plan. It has more adaptable/ changeable when the kids grow up and move out. The bathroom is bigger and incorporates a seating/twin bed near the front.
Here's the rough electrical that is already in place.
Matt
Old 02-22-2018, 07:29 PM   #114
rugjenkins's Avatar
1975 Argosy 28
Great day for the argosy today! I cleaned up the basement where I had put all the spare parts. My daughter who is 12 comes down stairs and says "wow, I've never seen this area of the garage before- in my whole life".
I pulled out all the skins and endcaps plus all the cabinet stuff. Not reusing the front endcaps. Tomorrow I will begin to make a new out of wood.
Matt
Old 02-24-2018, 06:43 PM   #115
rugjenkins's Avatar
1975 Argosy 28
It's been a productive few days! I don't like the front abs end-cap so I'm making a new one out of utility underlayment. It's thin and I like the wood pattern. I'm buck riveting it together. I really like the look. But 3/8 buck rivets are too short and I have to use washers on the back side to make it work. Click image for larger version
Matt
Old 02-24-2018, 07:06 PM   #116
rugjenkins's Avatar
1975 Argosy 28
Washed all the interior skins. Krud Krutter is the way to go. Click image for larger version
ID:	304898Click image for larger version
Matt
Old 02-24-2018, 07:08 PM   #117
rugjenkins's Avatar
1975 Argosy 28
Started priming all the interior skins. Click image for larger version
Matt
Old 02-25-2018, 06:40 AM   #118
rugjenkins's Avatar
1975 Argosy 28
I have this hard to find leak on the panoramic window. I resealed them 2 years ago with trempro. This leak is persistent! I removed and resealed. Leak! Resealed the seams at the endcaps. Leak! Resealed the seams on the side frame of the window. Leak. Today I think I finally found it- a leaking rivet. I know they can cause a leak but I didn't believe it. I believe now! Ordered captain trolleys creating crack cure! I will succeed! Update when it come in.[emoji1][emoji375][emoji354]
Matt
Old 02-25-2018, 10:07 AM   #119
chrisetmike's Avatar
1967 26' Overlander
Haute-Aboujagane , New Brunswick
Originally Posted by rugjenkins View Post
It's been a productive few days! I don't like the front abs end-cap so I'm making a new one out of utility underlayment. It's thin and I like the wood pattern. I'm buck riveting it together. I really like the look. But 3/8 buck rivets are too short and I have to use washers on the back side to make it work. Attachment 304895
Can't wait to see the results. Great idea!
chrisetmike is offline   Reply With Quote
Old 02-25-2018, 09:17 PM   #120
rugjenkins's Avatar
1975 Argosy 28
After much studying on the new endcaps. What I have first started will not work right. Winging it usually doesn't work. So I took more measurements and believe I have a great plan that will work. More to come.
Matt
