Old 02-16-2016, 03:41 PM   #71
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Yes, the wheel wells were cracked and flimsy. I accidentally burned the interior ones (over zealous taking out the olds&#128513. I can't remember if they are caulked and screwed into the frame. They are attached to the exterior skin with rivets. Should be two sets of trim. One goes over the other. The wheel wells and 2nd trim piece are riveted together. The wheel well fits into it. Undo the rivets and it should come apart. I made new ones out of 20 gage sheet metal. Hope this helps. Click image for larger version
Name:	ImageUploadedByAirstream Forums1455662335.725422.jpg
I'll post some pics if the trim and how it goes together when I get home
Matt
rugjenkins is offline   Reply With Quote
Old 02-16-2016, 04:43 PM   #72
rugjenkins's Avatar
1975 Argosy 28
Here's the pics of the wheel well trimClick image for larger version
Name:	ImageUploadedByAirstream Forums1455665914.774014.jpg
ID:	257369Click image for larger version
Name:	ImageUploadedByAirstream Forums1455665941.187730.jpg
ID:	257370Click image for larger version
Name:	ImageUploadedByAirstream Forums1455665959.691070.jpg
1st pic - inner trim that attaches to skin and wheel well slides into the rivet both together
2nd pic- outer trim that goes over 1st trim
3rd pic- under side of wheel well and 1st trim piece.
The bolts are usually rusted out- vise grips and bend to break. Other wise is used a cutoff wheel or grinder.
Hope this helps
Matt
Old 02-18-2016, 08:32 PM   #73
rugjenkins's Avatar
1975 Argosy 28
Installing 2 in foam on underside of floor. This stuff is not cheap! Click image for larger version
Name:	ImageUploadedByAirstream Forums1455852381.273245.jpg
I think it will help on sound deadening too.
Painting the belly wraps so I can install them Saturday! For me this will be a huge milestone. All the exterior back together. Click image for larger version
Name:	ImageUploadedByAirstream Forums1455852574.040121.jpg
The paints not perfect but if can live with it. I may paint the camper soon, before the pollen hits this spring. I don't have a paint booth so I'll be painting it outside. I know it won't be perfect but it will look great anyhow😜
Matt
Old 02-18-2016, 09:18 PM   #74
1962 22' Safari
Brooklyn , New York
What's the idea behind painting the belly pan? Are you making yr entire argosy black?
my current shell-off: http://www.airforums.com/forums/f44/...ht-144874.html
skyclad is offline   Reply With Quote
Old 02-18-2016, 09:29 PM   #75
rugjenkins's Avatar
1975 Argosy 28
No not the whole camper. I'm thinking of incorporating shiny metal and paint.
Matt
Old 02-18-2016, 09:31 PM   #76
rugjenkins's Avatar
1975 Argosy 28
Maybe something like thishttps://www.google.com/search?q=painted+airstream&ie=UTF-8&oe=UTF-8&hl=en&client=safari&safe=active#imgrc=kEEVkbiuHQ MhfM%3A
Matt
Old 02-18-2016, 09:51 PM   #77
rugjenkins's Avatar
1975 Argosy 28
Drying time is as slow as molasses using mineral spirits to thin. I'll use naphtha next time
Matt
Old 02-18-2016, 09:53 PM   #78
rugjenkins's Avatar
1975 Argosy 28
http://www.rv123.com/blog/painted-ai...b2b0830a04282/
Matt
Old 02-19-2016, 07:30 AM   #79
1975 Argosy 26
Tulsa , Oklahoma
Matt - Quick question I was thinking about the other day. Once you put the floor in, and put the insulation in, how do you fasten the bottom pan back to the Trailer ? Mine had Buck Rivets that I removed, and with the floor installed I wouldn't be able to get a bucky bar behind them. Do you just use sheet metal screws or something similar?
DDOK is offline   Reply With Quote
Old 02-19-2016, 08:46 AM   #80
rugjenkins's Avatar
1975 Argosy 28
I will use sheet metal screws with flat and lock washers, just in case I need to get back under there. Many use wide flange rivets.
On mine the belly wraps were overlapped on the skins. To much opportunity for leaks. My shell is jacked up 4 inches so I can underlap the belly wraps to the shell. I will use screws to attach the bottom half. I'll post pics this Saturday.
Matt
Old 02-20-2016, 06:53 PM   #81
rugjenkins's Avatar
1975 Argosy 28
2 in foam is done on outrigger sectionsClick image for larger version
Name:	ImageUploadedByAirstream Forums1456019605.919376.jpg
Matt
Old 02-20-2016, 06:57 PM   #82
rugjenkins's Avatar
1975 Argosy 28
The milestone starts- 1/3 finished with the belly wraps.Click image for larger version
Name:	ImageUploadedByAirstream Forums1456019730.667357.jpg
ID:	257599front door sectionClick image for larger version
Name:	ImageUploadedByAirstream Forums1456019816.180783.jpg
ID:	257600rear door section with cloes
Matt
Old 02-20-2016, 09:18 PM   #83
1975 Argosy 26
Tulsa , Oklahoma
Thanks again Matt for the info. Also, looks like you did a great job removing the paint !
Old 02-21-2016, 07:05 AM   #84
1962 22' Safari
Brooklyn , New York
Looking great! How are you finding the buck rivet process? Having not started it yet, I'm feeling a bit nervous about it
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
