Old 10-06-2003, 04:13 PM   #1
aviontt's Avatar
, Connecticut
Argosy question?
Does the 1975 28' Argosy TT have gray & black holding tanks or just the black. I'm thinking about buying one soon not sure if they have both....... Thanks
aviontt is offline   Reply With Quote
Old 10-06-2003, 05:02 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
If Argosy's followed the same timetable as the traditional Airstreams, grey water tanks were introduced in '73.
Shari
Old 10-06-2003, 05:26 PM   #3
aviontt's Avatar
, Connecticut
Hope this is the case...Thanks, Jeff
Old 10-07-2003, 06:04 AM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Argosy question?
Greetings Jeff!
Yes, the 1975 Argosy line did feature both gray and black water holding tanks according to the literature that I have. The question that I can't answer is whether the gray water tank on the model that you are considering collects the water from the shower/tub in the bathroom. On the Minuet series (1977-1979), the gray water tank is mounted above the floor (more or less beside the blackwater tank in the streetside corner) so it is higher than than the shower and thus does not collect the water from the shower.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 10-07-2003, 10:19 AM   #5
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Wow Kevin!
I have a 75 Argosy, and I haven't even thought about where the shower drained to... I always assumed it drained to the grey tank, but now I'll have to check - I'd hate to use it and have the black tank back up into the shower a la others I've heard on the forum - YUCK!
Yes, my 75 has the grey tank.
Marc
Old 10-07-2003, 12:26 PM   #6
I had a '75 26' Argosy which did not have a grey tank. Only a small above the floor black tank.
Elliott B
ElliottBartlett is offline   Reply With Quote
Old 10-07-2003, 04:09 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
And, just to muddy the water, my '72 has a grey water tank...
Old 10-07-2003, 04:24 PM   #8
Tikihut's Avatar
1977 Argosy Minuet 6.0 Metre
schaumburg , confusion
Send a message via AIM to Tikihut
My 77 has both a gray and black tank. Also my shower is not connected to either tank. I must use a external tank for my shower
Chris
WBCCI #2732
Tikihut is offline   Reply With Quote
Old 11-19-2003, 08:42 PM   #9
The Painted Pig
Moonshot's Avatar
1979 Argosy Minuet 7.3 Metre
Hailey , Idaho
Images: 14
Minuets could well be called Mystery-ets sometimes.
I noticed a small leak in my black tank on my last camping trip and when I removed the access panel and removed the insulation today to start work on it I found the shower drain in my 2.7 meter Minuet goes.... into my gray tank, not the black tank like other Minuets! My gray tank is not beside my black tank as on other Minuets. It is located below the floor on the streetside about three feet from the rear. So, with my 7.3 meter I have a gray tank that can be and is serviced by the shower along with the sinks.
Also, while I was at it I looked for the aluminum composite floor that some Minuets have in them. Alas, I saw only plywood in the bath area.
Scott
Moonshot is offline   Reply With Quote
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
rear door - trying to post nu2argosy All Argosy Trailers 23 06-04-2014 09:20 AM
Argosy 24 MH Fuel Capacity Question outbound Airstream Motorhome Forums 6 05-12-2004 03:37 PM
Argosy 24 MH Tow Capacity Question outbound Argosy Motorhomes 3 03-14-2004 11:35 AM
Argosy Question aviontt All Argosy Trailers 4 12-06-2003 05:19 PM
