Old 11-18-2006, 03:20 PM   #15
Dazed,Confused,Broke.
1978 24' Argosy 24
Hephzibah , Georgia
Originally Posted by BillyP
Serg
I have a 78 Argosy 24, with both the over head light AND the same setup as Marc Describes, Dual switches one above the other on the striker side .. the exterior "spotlight" I like to call it is between the door and the Front Streetside window.. the power is derived through the dual switch, although i have not pulled the panels yet to fully investigate routing, i will post pics as soon as i get the camera and computer to recognize one another, and can resize the pics to fit the website..
Sorry it took so long, here is the pic, remember this is a before restoration pic, so ignore the work that needs to be done
Name:	Argosy24 doorlights.jpg
BillyP is offline   Reply With Quote
Old 11-18-2006, 06:05 PM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I have changed the bulb in the above-door outside light by lifting a corner of the plastic lens, and letting it fall through the housing into my waiting hand. Change the light bulb (should be a #1141) and slide the lens back up into the hole, and work it around until it settles into place.
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
Argosy trailers 83Excella All Argosy Trailers 36 07-30-2011 12:26 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-02-2002 11:21 PM
