Old 08-11-2003, 09:50 AM   #15
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
low rider
Chas and all:
We are going to try to attach pictures of what we referred to earlier as the slugs that were inserted in to our new axil along with the torsion arms that attach to the splines.
loudruff is offline   Reply With Quote
Old 08-11-2003, 09:53 AM   #16
loudruff's Avatar
1989 29' Excella
Post Old & New Axle
This is the old axle next to the new axle. Yellow part is the new axle the old axle is next to it and rusty brown
Old 08-11-2003, 09:55 AM   #17
loudruff's Avatar
1989 29' Excella
This shows a detail of the torsion arm and shock mount. The shock mount was removed and welded to the new spindle.
Old 08-11-2003, 09:56 AM   #18
loudruff's Avatar
1989 29' Excella
New axle in place. Wheel well is cleaned up and painted.
Old 08-11-2003, 09:58 AM   #19
loudruff's Avatar
1989 29' Excella
Backing plate and drum attached.
Old 08-11-2003, 10:02 AM   #20
loudruff's Avatar
1989 29' Excella
New ride height 13" clearance under axle. Note wheel well to tire clearance height. Finally ready to test by taking a trip to Chicago this weekend.
Old 08-11-2003, 03:24 PM   #21
Chas's Avatar
Images: 22
Very interesting!
Thanks for the pics. So that is what the insides of a torsion axle look like? Looks like you could fab up just about any axle configuration possible, cut the tube to length, press in the torsion stubs, connect the arms to the proper degree and your done!
Do you have any brand names on any of these components?
Chas
Chas is offline   Reply With Quote
Old 08-11-2003, 07:20 PM   #22
loudruff's Avatar
1989 29' Excella
components
"Slugs" and spindles were products made by Goodyear. This company had several pallets of 3 different sizes/weight ratings. But by trimming the rubber blocks at different lengths, it offers an infinite selection of torsion spring weight. The supplier I used was a local axle manufacturer that has been making replacement axles that take the place of Henshen. Seems to be a good market. Hope the pictures have helped. Not a very difficult job once you have it jacked up!
Larry
Old 10-10-2004, 08:36 PM   #23
till's Avatar
Lisle , Illinois
Images: 108
WOW Larry, great reading!!
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 10-10-2004, 10:23 PM   #24
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Argosy Minuette 6.7 metre low rider
I had the pleasure of meeting Larry and Lou at the Midwest AirScream Rally this past weekend, and was able to see the fantastic difference that the new axle made in the ride height of their coach. The difference in ride height between the new Henschen DuraTorque that I had installed on my 6.0 Metre Minuet and the new axle on Larry and Lou's coach is tremendous. The new axle on my coach only increased the ride height about 1.5" so I still have to be very cautious about approaching driveways with steep drainage dips. While I am happy with my Henschen replacement axle, I would certainly have appreciated the greater ground clearance for day-to-day towability.
While visiting about our Minuets, we learned that both of our coaches still have their original issue Argosy Step Stools that were used rather than the typical fold-down steps - - Larry and Lou's is only the second such step that I have encountered among Minuet owners. A photo of the Argosy Step Stool is below:
It was interesting to compare notes with another Minuet owner who has links with the original purchaser of the coach.
Kevin
Kevin D. Allen
AIR #827
Old 05-25-2009, 11:58 AM   #25
Obsessed with Moonunit
COArgosy78's Avatar
Love It Here , Colorado
Images: 55
GVWR, Axle Weight Rating and such...
Hey Larry - I have had an ongoing conversation w/others on the forums after I posted a question related to the old axle on our 6.7metre. I am wondering if you, after having your new axle created, know what your new axle weight rating is? Is it 3300 (as Andy says that is what our old ones were rated), 3500 (that is what we have been told to put on) or higher?
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
COArgosy78 is offline   Reply With Quote
Old 05-25-2009, 01:03 PM   #26
loudruff's Avatar
1989 29' Excella
From our notes: The cost of the torque flex was $366.98....the year that we decided to fix the problem. It has a 3500 lb. weight rating. 4000# axle might be a bit high (at least a little hard for our little Minuet). These coaches were built pretty light. We worry about shaking it apart. But we are towing with a 1 T. van. A 4000 lb. spring may ride hard. We have played with height adjustments since ours is indeed adjustable and settled for a wheel well measurement of 25.5 inches...Marathon tires with 55 psi. We have had the axles from 2004-2009 and we are still happy with this measurement. At 30-34" seemed unstable, with lots of wiggle and seemed top heavy. This is without weight distribution hitch but with friction anti-sway. At 25.5" it tows great!
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
Old 05-25-2009, 02:17 PM   #27
COArgosy78's Avatar
Images: 55
Thanks for those details!!!! Noticed you added to my Axle confusion post (haven't read your comments yet). I guess I was a little rattled when I first posted it, especially after Andy said our original axle rating was 3300. But I feel the 3500 being recommended to us is going to work. You just confirmed that here. Thanks again.
Old 06-21-2009, 07:47 PM   #28
KAYAKAMPERS's Avatar
1966 26' Overlander
Stone Mountain , Georgia
Can you post photo again??
Kevin
Kevin, can you post that pic again. Chris made a step for us, but we would like to be on the lookout for an original one.
_______________________________
Beth Wallace & Chris Sanor
1966 26' Overlander International
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
KAYAKAMPERS is offline   Reply With Quote
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
rear door - trying to post nu2argosy All Argosy Trailers 23 06-04-2014 09:20 AM
Argosy Info jgriffith All Argosy Trailers 10 10-01-2006 08:45 PM
Could I use '70s Argosy for Temporary Relo? jburnes Airstream Motorhome Forums 9 11-16-2003 12:01 PM
WBCCI Numbers on Argosy overlander64 Our Community 2 06-26-2003 04:21 PM
