Old 08-11-2010, 02:42 PM   #1
1973 Argosy 22
Shepherdsville , Kentucky
Question Argosy Minuet
How can you tell if your Argosy is a Minuet or other model?
ccarman is offline   Reply With Quote
Old 08-11-2010, 05:48 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Argosy Minuet
Greetings ccarman!
Welcome to the Forums and the world of Vintage Argosy ownership!
There are a number of clues to the true identity of an Argosy Minuet including:
  • The coach was produced between 1977 and 1979.
  • The coach falls into one of the following size classes:
    • 6.0 Metre identified as 20' in VIN -- (Single Axle)
    • 6.7 Metre identified as 22' in VIN -- (Single Axle)
    • 7.3 Metre identified as 24' in VIN -- (Tandem Axle)
  • The coach has a Minuet badge in the belt-line molding on each side of the coach.
  • The floor width of the coach is 7' rather than 7' 8".
  • The interior cabinetry is vinyl-clad aluminum rather than laminates or hardwood veneer plywood.
  • An absolute identifier in the 6.0 and 6.7 Metre Minuets is if the floor is one of the many 6.0 Metre or one of the few 6.7 Metre Minuets to have been produced with an aluminum composite floor.
Kevin
Kevin D. Allen
AIR #827
Old 08-11-2010, 08:14 PM   #3
The Painted Pig
Moonshot's Avatar
1979 Argosy Minuet 7.3 Metre
Hailey , Idaho
Images: 14
Kevin hit the high points. I don't have much to add, except if you are trying to tell a Minuet at a glance look at either the front or rear windows as these are narrower than the standard Argosys. The curved vista windows are the same size on both units.
Moonshot is offline   Reply With Quote
A/C help! Argosy minuet 6 metre MyHappyPill All Argosy Trailers 5 07-20-2010 12:36 AM
'77 Argosy Minuet 6.0 Metre duo_77340 All Argosy Trailers 44 08-13-2008 09:55 AM
Argosy Minuet value? Anon Trailer Values 9 05-13-2007 12:24 AM
Argosy Minuet anniefanny Member Introductions 7 04-25-2006 08:12 AM
