Old 04-01-2011, 08:44 PM   #1
dlb56hdt's Avatar
1974 Argosy 28
Morro Bay , California
Argosy Manual
I have been an owner of a 1974 Argosy for three days now and I am a bit overwhelmed as to where to start. I have ordered my 30 dollar manual and am awaiting its arrival eagerly. Does the manual have part numbers to order by? How do I run the ID number? The surface of the trailer is dull and rough I had planed to pressure wash it and possibly use a Scotch bright pad to clean the oxidization off. Any assistance would be appreciated. Thank you.
dlb56hdt is offline   Reply With Quote
Old 04-01-2011, 11:17 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Another Argosy
If you pressure wash it, I would think you will certainly find out where it leaks. I have a '74 Argosy 26'. I have become very familiar with all aspects of the rig.
If the paint is just oxidized; I would try using a good cleaner that you would use on a car or truck, then use a good quality polishing compound designed for oxidized paint. Then wax it, once it is clean.
If there is anything I can help you with. Plumbing, electrical, mechanical etc. I'll be glad to help.
Maybe you could post some pics.
Old 04-02-2011, 10:12 AM   #3
dlb56hdt's Avatar
1974 Argosy 28
74 Argosy
Thank you for responding. I have ordered the Manual for my Argosy. Would you know if it will have part numbers that will help in locating parts? I have a broken hinge on the door and would like to replace the hinges ASAP. Are replacement parts readily available for the 1974 Argosy? I will limit my questions so as not to wear out my welcome. Thank you.
Dan
Old 04-02-2011, 12:16 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Dan!
Dan
Your Argosy owner's manual won't have any part numbers listed. There are illustrations of some assemblies, but it is not a technical repair manual. The manual's purpose was to help new owners understand how the various systems operated.
So far as I have been able to determine, there wasn't a specific Service Manual for Argosy coaches, but the similar year Airstream Service Manual would be a good substitute as both coaches are structurally similar with primary differences in levels of standard equipment and the painted or natural Aluminum.
A good number of parts are still available for our Argosys through Airstream. Airstream dealers or service centers can order parts for you; and there are several sources for reproduction parts including, among others; Vintage Trailer Service, and Inland RV.
Good luck with your Argosy!
Kevin
Kevin D. Allen
AIR #827
Old 04-02-2011, 02:20 PM   #5
dlb56hdt's Avatar
1974 Argosy 28
Thank you.
Service Manual Flaboy67 1970 - 1973 Sovereign 5 06-24-2016 10:04 AM
Desperate and dopey newbie needs Manual surfscoter 1960 - 1964 Overlander 15 05-19-2011 08:33 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
