Old 04-04-2011, 10:30 AM   #1
shortcake's Avatar
1972 Argosy 20
Talking Argosy maiden voyage.
I drove 1.5 hours to destination on my first trip with the Argosy. Overall the trip was great. My combo was my 2006 V6 Touareg, 20' 1972 Argosy with new tires, a Eaz-800 WD hitch, Prodigy brake controller.
I probably overdid it in preparations but still had a couple of issues.
Both the AD and hitch shop drove a block or so with me to show me how to work the brake controller. Airstream dealer set Prodigy on boost and very high number. Hitch shop set on b1 boost and only a 1 in the number setting. I read some posts here and saw some argosy owners were setting in mid 3's, so I did that. Had to stop fast at one light on the highway and something kind of skidded around(not sure if car or trailer). I found it frustrating that I got two such different suggestions on how to set brake controller. Guess I'll try to find a big empty parking lot and look for that 'grab' but I haven't felt it yet - unless that was what happened at the stoplight. Also Airstream dealer didn't put on a breakaway kit after I told them to "make it safe". The hitch shop caught it...not impressed with dealer.
The dump valve was closed while parked. We had a city water connection and there seemed to be a steady fast drip out of the valve when water wasn't turned on inside(looked clear). Is that normal? I thought it was probably residual water from sinks but we had to limit use of water due to stinky slinky hose issues. The AS dealer said they did a water line check, and no leaks, do I need to follow back up with them on this?
The Gator stinky slinky I bought at Camping World would not snap onto my dump valve outlet. I had to improvise with rubber gloves and duct tape - not fun. Any owners had similar problem? Is there an adapter I need?
That is how I noticed the drip... is the hose would not stay attached all weekend. The dump valve cap broke so drove back with valve closed but not capped.
Lastly the place where we stayed was nice and good view but the dump inlets all looked full in the am - gross! - is that normal as well?
I was white knuckling it both ways after reading so many posts here on blow-outs. I have a single axle. I'm really hoping that doesn't happen. I checked the tire pressure about a 100 times.
Next trip in one month only 30 minutes away which is a bit of a relief.
Kathy
shortcake is offline   Reply With Quote
Old 04-04-2011, 01:11 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Tanks and Brakes
The waste system on your trailer is probably the original Thedford and they do take their own twist on fittings. There are adaptors out there that will work. It took a while but I finally managed to get a system that works.
I would fill the grey water tank with fresh water and let it set to see how long it will drip. You can also operate the slide valve a few times while there is water in the tank. It could be as simple as the seal has soap scum or something on it and it may flush out to where it won't leak. You may be aware of this already, but you should drain the black water first, then the grey when you are on the road.
The way I set up my brake controller is to drive down the road at 5 to 10 mph. There is a hand slide control on my controller that I can operate manually. There is also a gain control knob. I adjust the gain control to the point where I can just feel the brakes come on, on the trailer when I slide the hand control to its maximum position, I don't apply the TV brakes when doing this. The best way I have found to make sure there is not too much brake on the trailer is to pull it on a gravel road. If when I apply the brakes on the TV, the trailer tires skid; I back off on the gain slightly until the tires don't skid. Then double check it with the manual control to make sure there is still brake operation on the trailer. It sounds complicated but you will get the hang of it.
Of coarse all of this stuff on the brakes is assuming that they are properly adjusted on the trailer.
Old 04-04-2011, 01:15 PM   #3
Ottawa , ON
IIRC, my Tekonsha is always set at b1. Sometimes I use the manual slider button if I want to come to a relatively fast stop.
For your slinky, all you need is a Thetford to Valterra adapter; a couple of bucks at most RV places (or even Wal-Mart, I think). Our Gator came with one...
Old 04-04-2011, 01:36 PM   #4
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
You might want to think about a tire pressure monitoring system. I use a PressurePro system for my Argosy Minuet. It seems to work well.
I also use a Prodigy. I use B1 for most towing, but for "around town" towing I turn off B1. The initial boosted application of braking helps haul the trailer down from highway speeds, but I find it to be a bit jerky in stop-and-go or around town.
Tom
mutcth is offline   Reply With Quote
Old 04-04-2011, 02:21 PM   #5
shortcake's Avatar
1972 Argosy 20
Thanks!
Thanks everyone. I will get that adapter ASAP!
I don't think the '72 has a grey water tank, it just drains straight out (I think even if the valve is closed?)
Old 04-04-2011, 04:43 PM   #6
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
If it's like the old Airstreams, the gray water is a straight shot out, no valve. As you go down the road, water in the p traps in the wash stand and sink sloshes and you get some water in the drain which then runs out. A blue boy for gray water at sites where there aren't hook ups is a good idea.
You are wise to be careful and worried at first. This is new and many trailers are wrecked the first time out and close to home. As you play with the settings and drive more you will find you will get more comfortable with towing. Watching the mirrors, anticipating what is ahead, walking around checking tires at each stop, all become habit patterns for you.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 04-04-2011, 04:56 PM   #7
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Hmm . . . A "blue boy"? Newbie here. Help? Define?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 04-04-2011, 05:01 PM   #8
cameront120's Avatar
1972 25' Tradewind
A portable tank for waste water. Readily available at RV supply shops.
North Vancouver, BC
Old 04-04-2011, 08:57 PM   #9
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Kathy,
That is correct. You do not have a grey tank. All water from everything EXCEPT the toilet flows out below the shut off valve. I also have an Argosy 20 1972 model-Love it!!!
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-05-2011, 05:31 AM   #10
2011 31' Classic
Thanks, we'll look for one.
Old 04-05-2011, 06:51 PM   #11
Ottawa , ON
Curious why would you need one? Your trailer has huge tanks.
Old 04-06-2011, 02:35 PM   #12
2011 31' Classic
Aage - I'd like to have the option of moving some of the holdings out when we are in the local National Forests for an extended stay, without having to hook up and go to the dump. Is this silly?
Old 04-06-2011, 09:24 PM   #13
Ottawa , ON
I wouldn't call it silly... But personally, I would wait until you have experienced the need before buying a blueboy. Just one more large thing to carry around. And nobody will want their stuff to be close to it..
Look up "Navy shower" in the search engine, and think about ways to practise conservation of water when you camp; it might be an interesting game to play.
Old 04-07-2011, 04:57 AM   #14
2011 31' Classic
Good advice. First camp this weekend, if the Natl. Forest doesn't close down on us Friday at midnight.
Removing shower valve in 74 Argosy 24' twilder Sinks, Showers & Toilets 2 04-02-2011 08:28 PM
Maiden Voyage Khulse On The Road... 2 03-24-2011 10:13 PM
Maiden Voyage Successful! LawChick On The Road... 7 03-15-2011 02:31 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
Argosy Door TG Twinkie Doors & Locks 7 01-29-2011 06:11 PM
