Old 06-21-2010, 07:42 AM   #15
Ballwin , Missouri
Janet,
Can we pull our new Argosy 100 miles and check the tanks when we get it to the cabin?
MOSue56 is offline   Reply With Quote
Old 06-21-2010, 09:31 AM   #16
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Argosy is an Airstream?
Greetings Glen and Sue!
Originally Posted by MOSue56 View Post
Janet,
It isn't advisable to tow an Airstream product of the 1970s with the wast holding tanks having anything more than a minimal amout of waste in them. That being said, there shouldn't be any particular peril associated with towing your coach 100 miles without inspecting the tanks. Keep in mind, that if you don't check for contents you may have trouble dumping the tanks once you arrive at your cabin.
Another thing to consider is that should the black tank have build-up of any kind in it, this would be a good opportunity to address that by emptying a bag of ice cubes into the tank (press the flush valve on the toilet and hold open until all of the ice cubes have flowed into the tank) the ice cubes will act as a scouring device to break up any solids that have accumulated in the tank as road vibrations agitate the contents. The down-side is that you would then have a black tank that needs to be dumped when you get to your cabin.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 06-21-2010, 10:17 AM   #17
adore's Avatar
1977 Argosy Minuet 6.0 Metre
Mont-Laurier , Québec
Replacing the valve on the black water tank...
Originally Posted by Janet View Post
The waste tanks on our 77 are holding up well - the dump valve had to be replaced however. You should test for leaks before you get too far down the road....
Hi:
How hard is it to replace the valve? Any special recommendations a part from having to empty the tank before starting the process... hehehe...?
Do you have a brand and a part number for the valve and are the black and the gray tank valves, the same?
Thanks in advance for the advice.
A. Doré
adore is offline   Reply With Quote
Old 06-21-2010, 05:45 PM   #18
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Replacing the valve is not terribly difficult if you have worked with fitting plastic pipe before. If you are new to plastic pipe, take it easy, measure 2 or 3 times before each cut, try to do a trial assembly before you start gluing it together. You should take the belly pan down to check the sizes of the valves as I found the gray tank had a 2 inch valve while the black tank had a 3 inch valve. You can call Oasis RV in Tucson or Inland RV in California for the correct valves. They are Thetford for the 3 inch. You might also be able to do a rebuild on the valves using kits which saves on the time and trouble of cutting and fitting new pipe.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
ARGOSY value / AIRSTREAM brunoffrance Trailer Values 10 06-18-2010 07:32 AM
Argosy vs Airstream construction MichaelS All Argosy Trailers 21 04-07-2007 04:59 PM
Airstream or Argosy? merryecho General Motorhome Topics 48 11-17-2005 11:19 AM
Airstream vs. Argosy. Same? Different? ob1coby All Argosy Trailers 8 08-23-2004 09:53 PM
Airstream or Argosy?? spinster Airstream Motorhome Forums 3 06-21-2003 04:26 AM
