Old 06-05-2013, 11:33 AM   #1
U3270's Avatar
1975 Argosy 24
Fullerton , Cali
Argosy Inspection Advice
Hello Argosy Folk,
I am looking for advise on inspection a 1974 24 foot Argosy. The trailer looks nice in photos and has new laminent flooring, appliances, and sink. I don't want to make the mistake of purchasing a trailer that has been dolled up for a quick sale.
I am hoping to find pointers on problem areas and things to look out for that I may miss.
U3270 is offline   Reply With Quote
Old 06-05-2013, 11:43 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
In general, an Argosy's weak points are the same as a silver trailer's... places where water has leaked over time can weaken or rot the subfloor, the KT latch mechanism in the entry door is delicate, and ham-fisted modifications/"repairs" to the plumbing can be a headache.
The big rear bath is a double-whammy. That's an area prone to leaks from outside (bumper trunk directing water to the seam between the shell and the banana wrap, plumbing vents, big window) and the components of the bath itself can contribute to (plumbing and drains) or hide subfloor damage.
If a deadbolt has been installed, check carefully that it was done right (deadbolt mechanism in the body of the trailer, NOT the door itself, and the bolt shaved down significantly so the hole cut in the edge of the door doesn't have to be too large.
Print the helpful Trailer Inspector's Checklist and use it. You can skip printing the motorhome pages, of course. If this is your first time using the checklist, I'd suggest reading through it beforehand and thinking about what it's telling you to check, make notes about what's important to you and what's not, etc.
Then come back here and show us pictures if you like it, or if it's a horror show.
David
Old 06-05-2013, 11:57 AM   #3
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
Having just bought an 1976 Argosy 22', I can telll you a couple of mistakes that I made while buying mine. First of all check to make sure all towing elements are in good condition. Also, have the owner set it up for you a couple hours beforehand (which I did not) and have him light all pilot lights for furnace and water heater, etc. This way when you get there, you can make sure that all appliances, gas and electric, are in working order. I wish that I would have done this. Good luck and remember that there are lots of trailers out there, this is not the ONLY one.
crabbey1 is offline   Reply With Quote
Old 06-05-2013, 12:14 PM   #4
U3270's Avatar
1975 Argosy 24
Fullerton , Cali
AWESOME! Thank : )
Old 06-05-2013, 02:11 PM   #5
1977 Argosy 24
Milltown , Wisconsin
Make sure the refrigerator works, they are over a grand to replace.
ventport is offline   Reply With Quote
Old 06-05-2013, 03:06 PM   #6
1979 Argosy Minuet 7.3 Metre
Topping , Virginia
What you are looking for depends a lot on how much time, effort and cash you want to invest. A unit that old will probably require new axles brakes etc. How are the tires? Are the systems working as mentioned above? If the owner still has a tow vehicle I'd ask him to tow it while I followed and observed for a few miles then ride along with the owner for a couple of miles then hook up to my own TV for a couple of miles. With a new floor down its going to be difficult to check for rotted sub floors and leaks. Does the upholstery have to be renewed?
Good luck.
Paul
tarnished is offline   Reply With Quote
Old 06-09-2013, 09:42 PM   #7
U3270's Avatar
1975 Argosy 24
Fullerton , Cali
I pulled the trigger and purchased my first trailer. I want to thank you all for the help and advise that guided me through my process. I'm sure ill be asking many more questions in the near future.
Thanks again
Old 06-09-2013, 10:54 PM   #8
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Looks like a beauty. The adventure begins.
DryFly is offline   Reply With Quote
