Old 03-13-2013, 02:11 PM   #15
1973 Argosy 26
Shelton , Connecticut
Fresh water tank 73 Argosy
my tank is the same as the picture Tom S has up except mine is alittle bit bigger. Its 82x13 1/2 x 8 1/2 deep. even a rectangle tank I can make work because its under the front bed. If anyone knows where to get a square one I will also try that. Thanks for all the comments keepem coming. If I find a solution I will post it for the rest of you.
Ron
hotrodronnie is offline   Reply With Quote
Old 03-13-2013, 02:34 PM   #16
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
My images of the front gaucho/water tank are in the Argosy images section.
I also require assistance in the form of a "flow chart" or how to plumb in the water pump. PO failed to mention that.
Savage68 is offline   Reply With Quote
Old 03-14-2013, 02:20 PM   #17
1973 Argosy 26
73 Argosy water tank
my tank has filler neck in same place. I located 1, in NJ but the tank n crate free n shipping is over $ 600
Old 03-14-2013, 02:22 PM   #18
rogerdodger's Avatar
Fresno/Clovis , California
Originally Posted by Inland RV Center, In View Post
Roger.
Your tank is not the same.
Please notice where the filler neck is on the tank in Tom S photo.
There was 2 different tanks used back then.
We had an issue getting one of these before, but got it resolved.
One of them is 82 inches long, which we have.
Nope, mine is in the same place, you just can't see it because I capped it off, not using it any more.
Roger
rogerdodger is offline   Reply With Quote
Old 03-14-2013, 02:25 PM   #19
Ron
I researched new tanks before I decided to repair mine. Just be aware there are not very good warrantees, and some offer none.
Roger
Old 03-14-2013, 04:20 PM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Savage 68
From the tank outlet: to a strainer: from the strainer: to the inlet of the pump: from the pump to the cold water supply line in the coach.
To can put a 3 way Tee in the line between the strainer and inlet to the pump. This tee makes it easy to add RV anti freeze when winterizing.
Old 03-15-2013, 08:10 AM   #21
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
Originally Posted by TG Twinkie
Savage 68
Thanks TG
Old 03-15-2013, 09:44 PM   #22
1973 Argosy 24
Pearland , Texas
I have a 73 Argosy 24 foot with the same style round corner tank under the front gaucho. Around the filler neck was cracked also. I repaired mine using polyethylene ( the same plastic the tank is made of) and a soldering iron melting the crack back together and fillling in around it with extra plastic. I also agree that blocking the tank so that it cannot move around is a must so that no undue stress is placed on the repair. I fixed mine three years ago and not a single problem since. When mine was cracked I found the same advice here on the forums and was extremely satisfied with the results. Try to find something made of similar plastic to practice on first if youve never done it before, crack it, melt it back together and try to break it. You'll be amazed at how strong you can make it with a little practice.
Fujak is offline   Reply With Quote
Old 03-16-2013, 05:45 AM   #23
If anyone needs some of the polyethylene, I have some left over from adding the cleanouts to my tank, just PM me I will mail it to you.
Roger
Old 04-08-2013, 08:04 PM   #24
1973 Argosy 24
Sevierville , Tennessee
I just removed the tank from my 24' and have no plans on putting it back in If your still looking for one
Csfraley is offline   Reply With Quote
Old 04-08-2013, 08:08 PM   #25
1973 Argosy 24
I have one I'm not going to use
Im looking for help to get a new fresh water tank for my 1973 Argosy 26. It has 2 rounded corners to fit the shape of the front of the camper. If anyone has a phone number to Airstream or a plstic tank place that makes them. or any other info I would appreciate your help.
Ron
I removed it from my 73 it was in the front under gaucho
Old 04-09-2013, 09:33 AM   #26
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
If "sloshing" of the water in a large tank causes balance or momentum problems, you may want to consider what the Air Force
Does in its tankers, either tanks w baffles, hard to install after market, or, and this is easier, as long as you have to replace a tank anyways, consider two or three smaller after market tanks bolted down but connected by half or one one lines.
Jerry cans are ok but sort of defeats the purpose of having a turnkey camper, if you get my drift.
